Tip & How-To about Linksys WPSM54G Print Server
Installation CD for the print server
If you are having trouble going through the setup process on the installation cd do the following:
  1. Disable any encryption settings on your wireless router.
  2. Disable MAC filtering.
If these features are enabled during the installation setup process, the wireless features will not work unless you go into the admin settings of the print server by typing the IP address into internet explorer. Type in the correct encryption settings.
Linksys has a provision in the setup software to key in the correct encryption however the software doesn't put the information in properly. This will cause the wireless not to work and allow the print server to work only when it is wired to the network.
Encryption settings have to be entered through the administration settings of the router by typing in the IP address of the print server using internet explorer.
Linksys WPSM54G Print Server Logo
coda qoy
Sir
Checking or verifying the wireless settings of your Linksys Cable Gateway is important when connecting wireless devices to your network. This is the best route to take if you are unsure of your gateway's wireless settings.
The wireless settings that you need to take note of are:
  • SSID
  • SSID Broadcast
  • Wireless Security
To check the wireless settings on the Linksys gateway follow the steps below:
Step 1:
Access the gateway's web-based setup page. For instructions, click here. If you are using a Maccomputer to access the cable gateway's web-based setup page, click here.
Step 2:
Click the Wireless tab.
Step 3:
Look for Wireless Network Name (SSID). It is recommended to change the SSID to something unique.
Step 4:
Click the Wireless Security sub-tab and take note of the current Wireless Encryption Level and the Wireless SSID Broadcast if it is set to Enable or Disable.
If Wireless Encryption Level is set to No Encryption, this means that the wireless security on the gateway is disabled.
If Wireless Encryption Level is set to 64 Bit Encryption or 128 Bit Encryption, check the value under Default Key and take note of the Wireless WEP Key that corresponds to it.
I hope Your problem is Linksys router Problem is solved by now, In case You still need Linksys Router Help Then I Suggest you follow official Linksys Router Support URL Website mention below :
Linksys Support
Or
In case You still need online Linksys Router Support Then follow us On for Linksys Router Support
Mar 27, 2014 | Linksys WCG200 Router
Loss the setup CD-ROM
A setup CD isn't needed to setup the linksys wireless router.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 01, 2013 | Linksys (WRT54GC) Router
need drivers
You do not need an installation CD to setup your Linksys wireless router.
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
http://192.168.1.1
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 03, 2012 | Linksys Wireless-G WRT54G Router
Afriend gave me a Netgear Rangemax wireless router I don't have the instillation cd and I've never installed one could you help? I'm connected to qwest broadband and I have a Dell pc. My son just got the same pc for his room and I need help to install it.
If you are connecting to the wireless router using LAN cables only then you can ignore the wireless setup part.
To configure Netgear wireless router and the wireless cards in the laptop and PC follow these steps : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL : -
http://192.168.0.1
3. Enter the router setup, login and password : -
Login = admin
PW = password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 18, 2009 | NetGear RangeMax WPN824 Wireless Router...
cannot connect to internet without hard wire from router to compu
It does sound like you may need to upgrade firmware. Not sure what OS you are running as Netgear is still in the process of updating Vista firmware. Anyway here is the URL you need:
http://www.netgear.co.uk/product_support.php
You might like to try:
1. Disable Windows Firewall
2. In Internet Options Control Panel go to the connection tab and then the LAN Settings where you can uncheck the "Automatically detect settings" button.
3. If you have any third party software, I would get rid of this and ensure that the"Windows Zero Configuration" in the Services menu is set to "Automatic" and the status is started.
Interestingly, Anti Virus programs sometimes interfere with wireless set up - you could see if it helps by disabling it whilst configuring your wireless. It might also be worth trying to connect without any encryption code & see if that will connect - you can then sort out the encryption.
You might find this site of some use
http://www.vista4beginners.com/How-to-setup-a-wireless-connection
Mar 01, 2009 | NetGear WGR614 Wireless Router
1,442 people viewed this tip
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
