Tip & How-To about Cell Phones
Mobile Phone Tips & Tricks:
THE REBOOT TRICK
This should work on all software versions of the 6110.
1. Go to the Calendar (Menu-8)
2. Make a note or reminder.
3. Enter some text into the edit box.
4. Hold "Clear" until the whole text is cleared, then press "Back".
5. Press "0". The main screen will now be showing but a space appears on the screen. (you can't see it)
6. Enter 4 digits (e.g. 1234).
7. Use the down arrow to move the cursor to the left side of the numbers and the space (Down arrow twice).
8. Now enter 6 digits and press the call button.
Wait for a few seconds, the screen should start to flash and reboots. It should alsowork on other menus like the "Profiles" menu
Cell Phones Logo
how to reprogram n5610d-1
Wait for a few seconds, the screen should start to flash and reboots. It should alsowork on other menus like the "Profiles" menu.
Jun 30, 2011 | Nokia 6288 Cellular Phone
i have a samsung gt-b3410 and i cant creat an alarm for a birthday
Manage your calendar Learn to change the calendar view and create events. Change the calendar view 1. In Menu mode, select Organiser → Calendar. 2. Select View by → Day or Week. Create an event 1. In Menu mode, select Organiser → Calendar. 2. Select Create → an event type. 3. Enter the details of the event as required and select Save. View events To view events of a specific date, 1. In Menu mode, select Organiser → Calendar. 2. Select a date on the calendar. 3. Select an event to view its details. To view events by event types, 1. In Menu mode, select Organiser → Calendar. 2. Select More → Event list → an event type. 3. Select an event to view its details.
but if u want the thing u specifically asked for http://www.getjar.com/mobile/25220/birthday-reminder-for-samsung-gt-s5233-avila/?s=phones
Jun 15, 2010 | Cell Phones
calender problem!
To add, change, or delete a Calendar appointment from the handheld, follow these steps: To add an appointment
  1. From the Home screen, press the Menu key.
  2. Scroll to and select Calendar.
    • NOTE: To select, press the trackball.
  3. Scroll to and select desired date and time.
    • NOTE: Selecting exact date and time will default to that date and time when the appointment opens, however these fields can be changed so any date and time can be selected.
  4. Enter a Subject.
  5. Enter a Location.
  6. If desired, select All Day Event.
  7. If desired, scroll to and set the Start and End date and time.
    • The 'Duration' should update accordingly.
  8. Scroll to and set Time Zone as desired.
  9. Scroll to Show Time As.
  10. Select one of the following as desired:
    • Free
    • Tentative
    • Busy
    • Out of Office
  11. Scroll to and set Reminder time as desired.
    • The options range from None to 1 Week.
  12. Scroll to and set Recurrence as desired:
    • None
    • Daily
    • Weekly
    • Monthly
    • Yearly
  13. If desired, select Mark as Private.
  14. If desired, select Notes, then type any notes.
  15. Press the Escape key.
  16. Select Save.
To change an appointment
  3. Select the appointment to be changed.
  4. Adjust any options as desired.
    • NOTE: The available appointment options are listed in the portion above.
  6. Select Save.
To delete an appointment
  3. Select the appointment to be deleted.
  4. Scroll to and select one of the following:
    • Open the series (for reoccurring appointments)
    • Open this occurrence
  5. Press the Menu key.
  6. Select Delete.
  7. Select Delete again to confirm.
I would recomend that you powercycle your phone regularly. If you have anymore questions feel free to ask me.
Apr 25, 2008 | RIM BlackBerry Pearl 8100
Samsung SCH-u740 Calendar Appointment Problem
This is what I got from Samsung when I sent them a summary of the calender failing to deactivate, even after the appointment was removed.
Mine has been quiet for an hour so far:
Thank you for your inquiry.
How Do I Reset My SCH-u740?
To reset the handset follow the steps below:
  1. While in standby mode, press the OK button for Menu
  2. Select Settings & Tools, using the navigation keys
  3. Select Phone Settings (6)
  4. Select Security (6)
  5. Enter the lock code, default password is the last 4 digits of cell phone number, unless it has been changed
  6. Select Reset Settings (3)
  7. Highlight Yes, using the navigation keys
  8. Press the OK button to confirm resetting the handset to factory default settings
Note: All settings (Except Contacts) are reset to factory default settings
Apr 23, 2008 | Samsung SCH-u740 Cellular Phone
218 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
