Home | All Products | Perfection V200 Flatbed Scanner | Tips
LPI, PPI,DPI conversions
Basti
By Wiz Basti
Rank: Wiz
Rating: 85%, 779 votes
posted on Jul 19, 2008
Helpful
Here is a conversion chart for DPI (Dots per inch) to LPI (Lines per inch) or PPI (Pixels per inch)
180 DPI................31 lines/inch or 68 PPI
360 DPI................63 lines/inch or 138 PPI
720 DPI................127 lines/inch or 280 PPI
1440 DPI..............255 lines/inch or 561 PPI
2880 DPI..................510 lines/inch or 1122 PPI
If you plan to enlarge your image, it is better to enlarge it when you're scanning rather than in your application. Each time you modify
an image, you lose some quality. Keep in mind when you enlarge a small photo, such as a 35 mm slide or wallet-size photo, you'll need
to scan at a high enough resolution to retain your image quality, but not so high that your file size is too large to be efficient. You must
manually adjust the resolution (dpi) to maintain the same image quality when you resize your image. For example, if you have a 300
dpi 2 x 2-inch image that you want to enlarge to 4 x 4 (a factor of 200%), increase the Scale setting to 200% or change the resolution to 600 dpi.
Was this helpful?
Yes
No
2 people thought this was helpful
Can you Help with these Scanners problems?
Epson Perfection V200 Flatbed Scanner
Scanner dose not work, LED comes on but it dose not power...
When I click on Scanner to start my V200 Scanner, I get...
can i scan a document straight into a word document with...
How do you clean the table glass on the inside of the...
Hi there Could you tell me if there is a difference...
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
