Tip & How-To about Computers & Internet
How to adjust the page file size in Windows Vista
The page file (or swap file) is a portion of the hard drive that Windows reserves to use as additional memory when its needed. You can make the page file smaller or larger, or disable it completely.
1. Click the Vista orb.
2. Right click on Computer.
3. Select Properties.
4. Under Tasks on the left hand side, select Advanced system settings.
5. If the User Account Control window appears, click Continue.
6. Click the Advanced tab.
7. Under Performance, click the Settings button.
8. Click the Advanced tab.
9. Under Virtual memory, click the Change button.
10. Select the hard drive that you want to adjust the page file for. (Typically this will be the C: drive.)
11. If Custom size is not already selected, click the circle next to it to select it.
12. Enter an Initial size and Maximum size for the page file in megabytes. The maximum size must be equal to or larger than the initial size, and both values should be at least one and a half times the amount of physical RAM that is installed in the computer.
13. Click the Set button.
14. Click OK to save the changes.
15. Click OK again in the Performance Options window.
16. Click OK in the System Properties window.
17. Reboot your computer for the change to take effect.
If your computer performs erratically after changing the page file size, go back into the settings and either change it back to its previous value or try a new value. Virtual memory errors are a good indicator that the page file is not large enough to handle what Windows needs it to do.
Computers & Internet Logo
not enough virtual memory
Step 1:
Virtual memory is a portion of your hard drive that Windows sets aside to utilize as memory. When your RAM is over utilized, the operating system can swap pages of data to the hard drive to make more room. Swapping files, or paging, is slow, but it allows your computer to remain functional when your memory space is full. If your virtual memory space, or page file, fills up as well, you'll get an error. Fixing this issue is quick and the process is identical in safe mode or in a typical boot situation.
Change Virtual Memory Settings in Windows XP Click "Start" from the Windows desktop. Right-click "My Computer" and click "Properties." Select the "Advanced" tab and under Performance click "Settings." Select the "Advanced" tab and click "Change" under Virtual Memory. Click "System managed " to allow Windows to automatically adjust your Virtual Memory as needed. Click "Custom " to alter the memory space to your own specifications. Enter a value in MB equal to at least 1.5 times the of your computer's memory for the initial . Enter a value in MB no larger than four times your memory for maximum . Click "OK" and restart your computer for the changes to take effect.
Feb 13, 2013 | Microsoft Windows XP Professional
Flash MX 2004 configuration
there are few steps you can try
Create a fresh Login ID for your Windows OS
Login with new ID
Increase your Virtual Memory
remove the slack files in Temp folder, You can use ccleaner addition to disk clean up.
Secure the registry changes, (you may you use spybot tea timer)
Please let me know the details, like your current operating system, RAM, CPU, Exact version of your Flash MX
Good Luck
Mar 24, 2008 | Macromedia Flash MX
when a user starts a computer, portions of the operating system are copied from the computer's hard disk into memory.
Windows uses a swap file (page file) as memory, and is crucial for it to operate properly. Leave alone if this is what you are referring to.
Oct 23, 2012 | Microsoft Computers & Internet
196 people viewed this tip
David Payne
David Payne
