Tip & How-To about Computers & Internet
Porteus Guide for survival (Live Linux) USB flash-CD
Porteus is a linux distribution
customized for
USB drives and disks (live mode)
It is available as 64bit and 32bit solution to install
on
USB flash, CD,MP3 player, camera and hard drive.
As all the above done in a few steps is the subject of this Guide.
Porteus 64bit
Porteus 32bit
1) How to put Porteus on a USB flash drive.
1.a) Format the USB flash drive in the FAT32 filesystem. (Windows)
(MyComputer, right click on your USB flash drive, Format, File System = FAT32, start)
1.b) Download Porteus
http://porteus.org/index.php#
download: Porteus 64bit or Porteus 32bit
1.c) Porteus is distributed as a ISO image.
It is necessary to unpack it on your USB flash drives.
When you do this, you will see on your USB flash,
two new folders: boot and porteus
Open the folder
boot
and run
bootinst.bat (if you're in Windows).
or
bootinst.sh (if you are in Linux).
Then it will become bootable, ie. able to raise from your USB flash drive.
1.d) Then you need to restart your computer.
Depending on the options your motherboard, it is necessary when starting
your computer keyboard press: F8 or F12 or Esc, etc..
Thus you will appear a menu where you choose your USB flash drive.
After Porteus menu comes before you.
(If in your BIOS is not set options for boot from USB flash drives, you can
do so when you start your computer press the keys: Delete, etc..
Thus will appear in the menu where you can set which devices can be boot-able)
2) How to put Porteus on CD.
2.b) Porteus is distributed as a ISO image.
It is necessary to burn it to CD
using the option of your program to burn CDs
Burn CD ISO image (Windows - Nero / Burn Image to Disc, for example)
2.c) Then you need to restart your computer.
2.d) Depending on the options your motherboard, it is necessary when starting your computer keyboard press: F8 or F12 or Esc, etc..
Thus you will appear a menu where you choose your CD drive.
3) The Porteus Live mode
see all your Windows and all. partitions and you can now manipulate them.
3.a) Good collection of programs ie. modules:
http://www.forum.porteus.org/
3.b) You can start using your Porteus easily.
Computers & Internet Logo
need hard drive
Find a friend who can make A live USB, a USB flash drive containing a full operating system that can be booted. Live USBs are closely related to live CDs, but sometimes have the ability to persistently save settings and permanently install software packages back onto the USB device. Like live CDs, live USBs can be used in embedded systems for system administration, data recovery, or the testing of operating system distributions without committing to a permanent installation on the local hard disk drive. Many operating systems including Mac OS 9, Mac OS X, Microsoft Windows XP Embedded and many of the Linux and BSD distributions can also be used from a USB flash drive. Windows 8 is also capable of running from a USB drive, with Windows To Go.
Mar 23, 2015 | Computers & Internet
boot from usb
Introduction UNetbootin allows you to create bootable Live USB drives for Ubuntu, Fedora, and other Linux distributions without burning a CD. It runs on Windows, Linux, and Mac OS X. You can either let UNetbootin download one of the many distributions supported out-of-the-box for you, or supply your own Linux .iso file if you've already downloaded one or your preferred distribution isn't on the list.
Requirements
  • Microsoft Windows 2000/XP/Vista/7, or Linux, or Mac OS X 10.5+. Note that resulting USB drives are bootable only on PCs (not on Macs).
  • Internet access for downloading a distro to install, or a pre-downloaded ISO file
Features UNetbootin can create a bootable Live USB drive, or it can make a "frugal install" on your local hard disk if you don't have a USB drive. It loads distributions either by downloading a ISO (CD image) files for you, or by using an ISO file you've already downloaded.
The current version has built-in support for automatically downloading and loading the following distributions, though installing other distributions is also supported:
Oct 15, 2011 | Microsoft Computers & Internet
1,436 people viewed this tip
David Payne
David Payne
