Tip & How-To about Samsung Modem Configuration Software (413115)
How to Run Software.
Before you run any new software. Close out all programs running.. Insert the Software into the CD-ROM .It will prompt you to click Run or Save this Software .Click Run .Again it will ask you to Run this Software .Click Run and follow the prompts on the screen.The installation Wizard will appear when its time to install this Software. Be sure you Re-Start your computer after installing new Software
Computers & Internet Logo
how can i have hp psc 1510 driver and valid Win32
Here's the fix:
* First uninstall your current HP installation.*
Step one: Uninstall the printer driver and software
1.
Disconnect the universal serial bus (USB) cable from the computer.
2.
Insert the printer software CD into the computer.
3.
A prompt to uninstall the software displays. Follow the on-screen instructions to uninstall the software.
4.
Restart the computer.
Step two: Turn off the Terminate and Stay Resident (TSR) programs and other background programs
When the computer is turned on, a software group called the Terminate and Stay Resident (TSR) programs automatically loads. These programs activate some of the computer utilities such as the anti-virus software but are not required for the computer to function. Occasionally, TSRs prevent the printer software from loading so that it does not install properly.
In Microsoft Windows 98, Windows ME, and Windows XP, use the MSCONFIG utility to prevent TSR programs and services from starting up.
1. Click Start and then click Run. The Run window opens.
2. In the Open: box, type msconfig, and then click OK. The MSCONFIG utility window opens.
3. Click the General tab.
4. Select Selective Startup.
5. If there is a check mark next to Load Startup items, click the check mark to remove it.
6. For Windows XP systems only - Click the Services tab and place a check mark in the Hide All Microsoft Services box. Select Disable All.
7. Click Apply and then click Close.
8. Click Restart to restart the computer.
Unplug your USB printer cable and reinstall. That's it!
Visit the HP Help Documentation Page for this error.
Here's the text from their page in case the URL for this changes:
Issue
The printer software installation stops and the Printer Driver Unknown error message displays on the computer. This document applies only to products connected with a USB cable.
Figure 1: Printer Driver Unknown error message
Solution: Follow the steps below to resolve this issue.
NOTE: These instructions do not apply to Windows 2000 because the MSCONFIG utility used in Step two does not exist in Windows 2000.
1.
2.
3.
4.
NOTE: This step does not apply to Windows 2000 because the MSCONFIG utility does not exist in Windows 2000.
1.
2.
3.
4.
5.
6.
7.
8.
Step three: Install the product software
Listed below are several options for installing the product software. If the product software CD is not available, HP recommends downloading and installing the product software from the HP Website at www.hp.com.
Method one: Install the product software from the CD
1.
If the product software CD is still in the computer CD drive, remove it and re-insert it in the CD drive.
2.
If the software installation does not start automatically, follow the steps below.
1.
2.
In the Open: box, type D:\setup.exe, where D is the letter of the CD-ROM drive.
Follow the on-screen instructions to complete the software installation.
Method two: Download the software from hp.com
1.
Go to www.hp.com and click Software and driver downloads.
2.
Type the model number of your product in the Search box.
3.
Select the operating system of the computer to which the device is connected.
4.
Click the downloaded software to start the software installer.
5.
Follow the on-screen instructions to install the software.
Step four: Use the MSCONFIG utility to enable the Startup software
1.
2.
In the Open: box, type MSCONFIG and then click OK to start the MSCONFIG utility.
3.
On the General tab, select Normal Startup to automatically enable all features the next time the computer is started. In Windows XP, click the Services tab and select Enable All.
4.
5.
Click Restart to apply the changes to the computer.
Jan 20, 2015 | HP Computers & Internet
how to install microsoft office in my pc
Hi, You should the Microsoft Office CD. Close all running programs on your computer the insert the CD software to your CD Rom. The auto play will run your CD, if it is not run your CD rom manually. Follow the steps and guide on your screen till it completed. Note you wil prompted wit h CD keys during process ( find on cover of your CD software the CD key).
Regards
Jan 18, 2011 | Microsoft Office Professional 2007 Full...
can't get webcam to work on messenger, it used to work, I must be doing something wrong do h I have to download a program
Reinstall you webcam drivers doing the following:
Unplug your webcam from your computer.
  1. Reboot your computer.
  2. Insert your webcam's manufacturer installation CD into the CD-ROM drive and follow the installation prompts.
Note: If the setup program doesn't start automatically within a few seconds, you need to manually start the installation process.
To manually start the installation process:
  1. Click Start from the taskbar in the lower-left corner of your computer screen.
  2. Open the Run window and type d:\setup in the text area.
    Note: The "d" indicates the path to your CD-ROM drive. If your CD-ROM drive is located in a different path, you need to replace the "d" with the correct path.
  3. If you've downloaded the most recent software driver from the webcam manufacturer's website, run that installation program now.
    Note: Most webcam manufacturers maintain the latest webcam software drivers on the download or support areas of their website. Just download it and save it to your computer.
  4. Follow the instructions provided by the webcam setup program.
    Note: Plug in your webcam USB cord only when prompted. (This is usually done after rebooting your computer.)
Sep 09, 2010 | Yahoo Messenger
when i try to scan a photo my scanner says ''youneed to install or run hp software for this feature'' how do i do this?
Software included
HP Image Zone Photo & Imaging Software: HP Director, HP Photo Gallery, HP Image Editor, HP Instant Share, HP Photo Prints, HP Creative Projects, HP Quick 4 x 6 prints, HP Document Viewer, HP Send to Programs
The above software should be able to be run by inserting the cd-rom into your cd-rom or dvd-rom drive.
Once installed you'll be able to run the scanner.
Jul 09, 2010 | HP Officejet 7310 All-In-One Printer
How to install it in Windows Vista?
sure not hard at all. all you have to do is:
  1. Close all open programs on the computer.
  2. Locate the HP Photo & Imaging software CD-ROM that is appropriate for the language and operating system and insert the CD-ROM disk into the computer.
  3. For a Microsoft(R) Windows computer: Follow the instructions on the screen. Or, if the installation program does not start automatically:
  4. Click Start , then click Run . The Run window will open.
  5. In the Open box type: X:\SETUP.EXE (where x is the letter of the CD-ROM drive).
  6. If the instruction prompts to shut down the computer, do so.
  7. Connect the USB cable between the USB port on the scanner and the USB port on the computer.
  8. Connect the power cable between the scanner and a surge protector or a grounded wall outlet. This turns on the scanner.
  9. If necessary, turn the computer on again.
this product is no longer being supported by HP so here is a link to updated drivers if needed.
http://www.softwarepatch.com/utilities/hp-scanjet.html
hope this helps. please rate me and thanks for choosing enterprise computing solutions
Oct 07, 2009 | HP ScanJet 3500C Flatbed Scanner
576 people viewed this tip
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
