Tip & How-To about Cell Phones
Explanation for mobile internet & how to connect diff. mobiles to PC
~!~ What is GPRS internet?
General packet of radio services is the technology of providing Internet packet through Air (wireless) , Service is same as you gets from Dial up or ISDN but medium is differnent. [ Both are public switched data means speed allocated as avialable or shared service not the dedicated]
~!~ What is Edge?
Enhanced development in Global (OR GSM) Evolution is newer
(Newer for india ) technology in providing internet packets
with almost 3 times more speed and stability and three times
low congestion on network provider. You can only get it if your operator has
enabled this service in your area ( tower is EDGE enabled or not ) &
wheather your mobile is EDGE enabled or not ?
~!~ What is 3G?
3G stands for 3rd Generation, Newest wireless technology in india.
It has such enhanced features as high-speed transmission, advanced
multimedia access and global roaming. In short, it allows you to get IP
access while being mobile with your wireless device.In short It has the
advantage over Wi-Fi of not being limited to a few dozen meters
~!~ Whats is the difference in connection to p.c. between Nokia , Sony ericsson and Motorola
1. Nokia uses a Dedicated field for modem named PACKET DATA other than profiles that used by Mobile itself to access internet.
You have to dial *99# from your pc. it will dial whatever APN
you selected in PACKAET data of your Nokia mobile..
2. Sony ericsson have the same Profiles both for mobile and Modem through P.C. . You can dial diff. diff. profiles by dialing that no. from pc.
*99***1# means you are dialing first profile of your mobile
*99***2# means you are dialing second profile , According to you
dialed profile relevent AP would be dialed
3. In motorola First of all you have define in your mobile that USB cable you are using is for DATA To do this goto MENU >> settings >> usb >> n make DATA as default media. After this your mobile will work as a modem now You have to add EXTRA INITIALISATION COMMAND
from your P.C. and it will override evry setting of your mobile and P.C.
( You can use this in any mobile if you are facing problem in connecting)
To add E.I.Command goto Properties of Your Mobile Modem and click on
ADVANCE TAB. Here you can add this E.I. Command
Code: [Select] [nofollow]AT+CGDCONT=1,"IP","airtelfun.com
Remember do not alter anything except APN and the APN you'll define
would be dailed irrespective of what you have defined in your mobile.
One more thing i should mention here that the APN you are dailing should be activated for your no. (Contact ur operator to activate that)
~!~ How to setup your mobile modem in P.C.
Most of the latest mobile creat there modem itself , there is no need to
do anything just connect you mobile to cable and it will automatically
install it but remeber Pc. Suit should be installed.
In your computer Goto Control panel >> click on Phone and modem option (If you opened it First time then it will ask for country code enter it 91 or anything and press next) >> Come to MODEM tab >> Cick on ADD tab >>
In new window Select "Dont select my modem i will choose it from list" and press next >> Now choose your mobile company in left window and model in right window ( You can maually point for your drivers from HAVE disk in case you have them ) >> Now choose your Port and press next , Most probably you will get a Xp certificate notice just accept it and you are ready
~!~ How to make a connection From your P.C. to mobile modem?
In your computer Goto Control panel >> Network Connections >>
Click on new connection wizard >> A new window will open >>
Click Next on these new window >> Now choose Connect to internet and click Next >> Choose Set up my connection maually and click next >> choose Connect to dialup modem then next >>
Now choose your modem from list ( Choose only mobile modems ) next>>
Now Give it any Name - next >> This the place where you have to mention your dialup no. which is *99# or according to your mobile as i described above (You can change it lator) next >> If you have any username and password (Only for BSNL ) then enter it here else leave it intact >> Congratulations you have created a succesfull connection
Cell Phones Logo
my cell phone is lg gx500. my problem is the mobile internet are very slow and no downloads. can you ask me it use high speed internet on our lg gx500
Probably now you are using GPRS (General Packet Radio Service) or EDGE (Enhanced Data for Global Evolution) services on your phone.These services and their speeds are dependent on their Network service providers.However, these services cannot provide speeds beyond a limit (32-48kbps for GPRS and 135kbps for EDGE) and are not suitable for services like high speed internet surfing, video streaming and downloading.
You cannot use High speed 3G services on your LG GX500 because your phone doesn't support 3G technology.But you can connect your phone to a WLAN (Wireless LAN) Network (Your phone supports WiFi Technology) which are capable of high speeds (upto 54 Mbps).It can be from a public WLAN network or a WiFi modem.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jun 28, 2011 | LG GX500 Cell Phone
how to set globe grps setting?
Hello and Welcome to Fixya!
General Packet Radio Service (GPRS) is a packet-based wireless service used for sending and receiving data through the internet protocol. With GPRS, the transmitted data is divided into various 'packets' before it is received by the user.
It is important to note here that the setting for GPRS is different for different phones companies and may be different even for the different models produced by these companies.Therefore, it is recommended that you rely on the information given directly from the service provider. Again activation process may be different for postpaid and prepaid customers. So just call and demand GPRS settings by the service provider, They will send it free.
Any more confusion, queries or for further assistance, I am here to help.
I hope this solution helps you
Thank you for using FixYa!
Jun 19, 2011 | Nokia 5530 XpressMusic Smartphone
i cannot access the internet via my samsung b3310 mobile
Hello
Internet access on your mobile or mobile broadband is possible by connecting via GPRS (General Packet Radio Service). GPRS 2.5G is a packet-switching service. It allows you to access the Internet by sending packets of data over the Internet. You can send and receive email with GPRS. It supports WAP, SMS text messaging and other data communications. When you click on the Web icon on your mobile phone, you get connected to the Internet. For the internet setting/configuration on your mobile you may contact your mobile service provider by calling on help line or visiting their nearest office.
Hope it helps if so do rate the solution
Dec 27, 2010 | Samsung B3310 Cell Phone
what is PACKet data? steps to connect my phone to to web service
Answer: General Packet Radio Service is used mostly in Europe and Asia. GPRS is used most commonly for cell phones. In Canada, Rogers and Fido are using GPRS.
You can send and receive emails using GPRS and browse the Internet.
General Packet Radio Service is a radio technology for GSM networks that adds packet-switching protocols, shorter set-up time for ISP connections, it also offers the possibility to charge by amount of data sent rather than connect time.
It is a new nonvoice value added service that allows information to be sent and received across a mobile telephone network. GPRS is NOT related to GPS (Global Positioning System), a similar acronym that is often used in mobile contexts. Allowing information to be transmitted more quickly, immediately and efficiently across the mobile network, GPRS may well be a relatively less costly mobile data service.
GPRS can provide instant connections subject to radio coverage. No dial-up modem connection is necessary.
Dec 11, 2009 | Nokia 5130 Cellular Phone
phone is not ringing out loud, even when recieving or dialling
hello there!! Thank you for using Fixya.com;
General packet radio service (GPRS) is a packet oriented mobile data service available to users of the 2G cellular communication systems global system for mobile communications (GSM), as well as in the 3G systems. In the 2G systems, GPRS provides data rates of 56-114 kbit/s.
GPRS data transfer is typically charged per megabyte of traffic transferred, while data communication via traditional circuit switching is billed per minute of connection time, independent of whether the user actually is using the capacity or is in an idle state. GPRS is a best-effort packet switched service, as opposed to circuit switching, where a certain quality of service (QoS) is guaranteed during the connection for non-mobile users.
This GPRS can be acquired from your Service or Network Provider and there will be a minimum charge of amount on this and it depends from the Provider. You may just need to use a Mobile which supports this kind of feature.
Little more info about GPRS:
Services
GPRS upgrades GSM data services providing:
If SMS over GPRS is used, an SMS transmission speed of about 30 SMS messages per minute may be achieved. This is much faster than using the ordinary SMS over GSM, whose SMS transmission speed is about 6 to 10 SMS messages per minute.
For more information, you may contact your Network Provider.
Have a nice day!!!
Feb 15, 2009 | Sony Ericsson w580i Cellular Phone
206 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
