Tip & How-To about Televison & Video
Lamp Reset Procedures for Toshiba TVs.
You have replaced your lamp and the set is working fine but the 'replace lamp light' is still on. What do you do?
This is an important procedure because you need to know when it is time to replace the lamp again. If you do not reset the timer you may run the risk of having the lamp explode, because it was not replaced in time. This can be dangerous and could cause a fire. At the very least it will cost you more to repair.
The manufacturers goal for having a lamp timer is to get the customer to change the lamp prior to a catastrophic event happening. Most lamps only last for about 3 years and that equates to 6000 to 8000 hours when watched for more than 8 hours per day.
To reset first make sure the TV is unplugged from the electrical outlet.
1) Turn the main power switch to the "ON" position.
2) Press and hold the "On/Standby", "Menu" and "Input" buttons at the same time. The buttons are on the projection TV. Though the same buttons are found on the remote control, the reset only works with the buttons on the TV.
3) Plug the power cord back into the outlet while holding the buttons in Step 2.
4) The lamp timer will reset when the projector receives power.
This should reset your counter and you will be ready to enjoy your TV for about another 8000 hours or three years which ever comes first.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Televison & Video Logo
Mitsubishi DLP - WD-60737 - 1 year old I have sound but no picture. The lamp is not lighting up. I have already replaced the lamp. After I replaced it, the set worked fine for a couple of hours, but is now back to doing the same thing again. Both lamps still look brand new. Any ideas?
This tv has self diagnostic feature that will show last error through front light blinks, there is procedure to activate and read out error code to diagnose problem section of tv to solve its issue so to get tv back in business.
Let me know to proceed.
Thanks.
Mar 03, 2011 | Mitsubishi WD-60737 60 in. HDTV
RCA SCENIUM TV (HD50LPW175) NO PICTURE.SOUND FINE.
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Dec 27, 2007 | Televison & Video
1,305 people viewed this tip
Top Televison & Video Experts
