Tip & How-To about Televison & Video
You have replaced your lamp and the set is working fine but the 'replace lamp light' is still on or the lamp light is blinking. What do you do?
This is an important procedure because you need to know when it is time to replace the lamp again. If you do not reset the timer you may run the risk of having the lamp explode, because it was not replaced in time. This can be dangerous and could cause a fire.
Manufacturers have lamp timers built in to their TVs so that when it gets close to time to replaced the lamp you are made aware of this and if you heed the warning you may save money by not damaging other components such as the ballast. If you do not heed the warning, you are on your own and deserve whatever happens.
To reset first make sure the TV is powered off.
1) Point your remote towards your TV.
2) Press MUTE + 1 + 8 + 2 + Power.
3) Your TV should now say "Loading Factory".
4) Browse down to "Option" then press ENTER (or the right cursor button).
Note: The MUTE + 1 + 8 + 2 buttons need to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow acts as the ENTER button, so try it if you're having difficulty with the ENTER button.
5) To exit the service menu press the EXIT button or just turn the TV off. Do not turn on the TV immediately after. Let it off for several minutes.
This should reset your counter and you will be ready to enjoy your TV for about another 8000 hours.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
