Tip & How-To about Tools & Hardware - Others
Get Wooden Sliding Doors and Drawers to slide smoothly
I have a house built in the 70's and the previous owners built in cabinets along an entire wall with sliding wooden doors. I would have to pull and tug and tug to get them to open, and then they would often pull the other door open with them!
This would have been a situation where, with a different material other than wood, WD-40 would have been perfect! Of course I was working with wood, so that wasn't an option.
I finally took an ordinary bar of soap (nothing fancy with moisturizers or extra ingredients) and ran it along the wood where the cabinets slide. Bingo!
I have since used this method to make wooden drawers open and close smoother and I do touch everything up every couple of months with a little run across of bar soap!
Tools & Hardware - Others Logo
my main breaker panel feeding our entire house built 1996 is rated at 150A. Yet if I add up all the breakers inside, they total 600 amps !!! Is this a safety issue? Is it up to code?
No problem. You would never have a situation where every circuit in the panel was loaded to its max. The panel size itself limits the number of breakers, and total number of circuits. The 150 A breaker protects the box itself against too much load on the buses in the back that the breakers connect to. No worries about this.
May 10, 2017 | Electrical Supplies
The water isn't filling into water softner for setting up
Depending on the washing machine, it is supposed to have a gizmo inside the softner housing that triggers the water during the rinse cycle to flow into the softner dispenser. Sometimes, they go missing or are clogged with hardened softner. Open the door fully open and carefully prize the entire housing out. Clean it with hot water and put it back in. Some machines require the slide in tray be raised about 70 degrees (most common) and then pull out, others require a downward angle.
Mar 12, 2015 | Washing Machines
I have the serial number 06 1 00049 but need to clarify the model number which I dont have, in order to buy a part. I think it might be XOU493 after searching on Google
The model number is often located on a plate or sticker which is on the front of the oven chasis, usually running along an edge of an oven door.
If this is not visible or worn away, the manufacturer often has another sticker or plate either on the side or back of the oven. If it is a built in oven, you will need to undo the 4 or 6 screws holding the unit into the cabinet housing and then carefully pull it out. This task is best done with 2 people and a workmate or table to slide the oven onto.
Sep 07, 2011 | Belling Ovens
i want to fit a wooden door to a intagrated dishwasher stoves
If your dishwashermag-glass_10x10.gif door is not closing properly or has developed a leak, it may be time to replace the entire door assembly. Some other signs of a defective door include sagging, difficulty pulling the door back up into a closed position and a door that feels heavier as it drops open. Replacing a dishwasher door is not that hard, but includes several springs and hinges that must be aligned correctly or the door will not fit correctly in the opening.
  1. tep 1 Unplug the dishwasher and shut off the water before attempting to remove any parts. If you cannot reach the electrical outlet, you can turn off the breaker switch that controls the electricity for the kitchen. Remove the drain hose that runs from the dishwasher unit to the sink drain.
  2. Step 2 Pull the dishwasher out from the cabinet until you have clear access to the side of the unit. Ask a friend for help with this part if the unit is too heavy for you to slide out without straining your back.
  3. Step 3 Check your dishwasher's owner's manual to find out exactly how the outer door panels are removed. Some models have a two-panel door where the control panel must be removed before the lower panel will come off. Otherwise, the door panel should be one solid piece or a two-piece assembly that allows the lower section to be removed separately to access the springs and hinges.
  4. Step 4 Remove the springs at the bottom of the door. Depending on the type of dishwasher you have, there may be a tension adjustment dial or simply a series of holes at different distances from the edge of the unit. If you have a tension controller, adjust it to a loose setting to make it easier to remove the door springs. Unhook the door springs from the hinge plate. Some dishwashersmag-glass_10x10.gif may have a cable and pulley system attached to the door springs. Check your owner's manual for removal instructions if this is the case with your model.
  5. Step 5 Use pliers to gently pull back on the door hinge plate's tab until the slot opens for the hinge pin to come out. Take out the screws holding the door hinge plate onto the front of the door panel. Hold onto the door assembly while gradually opening the door. Once the door drops down, you should be able to remove it by sliding the door off the hinge pinAlways wear safety glasses when working with the springs and hinges involved with a dishwasher door assembly. These items can fly off at high speed and cause serious injury to the eye.
Nov 15, 2009 | Stoves 27 in. DW60 Built-in Dishwasher
I have a old wall built in thermador toaster & need parts
I have a Thermador built-in toaster ( new in box). It has never been used but I have had it for many years. Willing to sell.
Mar 29, 2009 | Kitchen Appliances - Others
1,009 people viewed this tip
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
