Tip & How-To about Computers & Internet
How to change Data Execution Prevention (DEP) settings in Windows 7? Data Execution Prevention (DEP) is a feature that protects our system from viruses and other security threats. The Windows constantly monitors the programs running on our system and closes them if they perform any malicious activity. But sometimes we want a certain program(s) to run even if the Windows alerts us that it is a malicious one. To change Data Execution Prevention settings in Windows 7 follow these simple steps: 1) Right click on the My Computer icon on your Desktop and select Properties. Fig. 1 2) The System window opens now. Here click the Advanced system settings link in the left pane as highlighted below: Fig. 2 3) The System Properties window opens now. Here click the Settings... button under Performance section under Advanced tab Fig. 3 4) The Performance Options dialog box opens now. Here select Data Execution Prevention tab and then click on the radio button Turn on DEP for all programs and services except those I select option and click Add button Fig. 4 5) Now select the Executable file (i.e. the .exe file of the program you want to add) that you want to add and click Open button Fig. 5 Note: If you try to add an executable file which cannot be turned off it's DEP feature, then you will receive a warning as shown below. Fig. 6 6) In the same way, to remove an executable file from the list select that file and click Remove button. 7) Click Apply and then OK button in the Performance options window 8) Click OK button in System Properties window 9) Close System window. Thanks for reading.
Computers & Internet Logo
data execution prevention as I am getting this messaGE WHENEVER i GO TO OTHER WEBLINK AND iNTERNET eXPLORER SHUTS OF SO i NEED YOUR HELP
There is two area's that DEP is held One in the perfomance section and the other in IE Firstly we'll fix IE DEP 1. Open up IE and quickly select Tools 2. Select the advanced tab 3. Uncheck the Enable memory protection 4. Restart IE to apply. 1. Start\Control Panel\System and Maintenance\Performance Information and Tools\Adjust visual effect 2. Select the Data execution prevention tab 3. Check the Enable DEP for Essential windows programs and services 4. Restart the computer to apply.Disable DEP using CMD A) In the command prompt, type bcdedit.exe set {current} nx AlwaysOff and press Enter.B You should get a success message back C Close the command prompt. D Restart the computer to apply. Enable DEP using CMD A In the command prompt, type bcdedit.exe /set {current} nx OptIn and press Enter. B You should get a success message back C Close the command prompt. D Restart the computer to apply.
If a program is being closed by DEP, then make sure that it is a DEP compatible version and check for an updated version. If it is not DEP compatible, then you can uninstall the program or turn off DEP for that particular program.Follow the steps below to to close Data execution prevention a. Click on start. b.Right click on Computer and click Properties.c. Click on Advanced system settings.in upper left green area d.Click on the Continue button in the UAC prompt.e Click on the Settings button under Performance section.f Click on the Data Execution Prevention tab. g. Turn DEP On for Essential Windows Vista Programs and Services Only.NOTE: This turns on DEP for only the 32 bit system programs and services. This is the default setting. h.Click on Turn on DEP for essential Windows programs and services only.click on OK to apply. j.Turn DEP On for All Programs and Services Except for the Ones you Select.NOTE: This turns on DEP for every 32 bit program except for the ones that you add to the list. The listed program will have DEP turned off for it.Turn on DEP for all programs and services except those I select. Click Add to add the programs that you do not want to use the DEP feature. m. Navigate to the program's .exe file that you want to add to the DEP exclusion list and select it, then click on Open. n.Click on OK to apply. b. Restart the computer to apply changes.
Oct 24, 2011 | HP Pavilion DV6000T 15.4­ NOTEBOOK LAPTOP...
how to enable or disable programs onDEP
To enable or disable Data Execution Prevention (DEP)
In windows XP,
  • Log in as administrator
  • Open the Start menu, right-click on My Computer and Choose "Properties" from the context menu.
  • On the "System Properties" window, click the "Advanced" tab .
  • click settings button under Performance
  • click the "Data Execution Prevention" tab
  • choose either "Turn on DEP for all programs and services except those I select:" or "Turn on DEP for essential Windows programs and services only to select the OptIn policy"
  • If you choose "Turn on DEP for all programs and services except those I select:", click Add to add the programs that you do not want to use the DEP feature.
  • Click OK twice
  • Restart the computer for the changes to take effect
I hope that you find this information helpful.
Mar 03, 2011 | Microsoft Windows XP Professional for PC
Windows 7 Enterprise 64-bit. Will not boot.
hi there, try booting your PC to safe mode. power on the computer and quickly tap the F8 key. keep on tapping it until you reach to black screen with different selections. select safe mode then press enter. once you gain access to windows safe mode. click start menu then accessories then system tools then system restore. choose a date where you remember your computer works fine then restore to that date.
Please let me know if you need more help.
thanks
Apr 08, 2010 | HP Elitebook 8730w Mobile Notebook
windows data execution prevention won't allow itunes to open!
ok try this then.
Press [windows]+Pause/Break to open the system menu (or control panel -> system) and press advanced systems settings on the side. Go to the advanced Tab, and press settings. Go over to the D.E.P. (Data Execution Prevention) tab, and press add, then add in iTunes and whatever else you need.
Oct 03, 2009 | HP Pavilion DV5234US Notebook Laptop
why do i keep getting DEP error message each time i close IE8 or a tab?
windows xp has DEP ( data execution prevention ) some viruses etc use that sort of technique and from SP2 onwards I believe it was they included it.
http://www.zensoftware.co.uk/kb/article.aspx?id=10002
Several OSs have no-execute or execute protection. Microsoft has added this as well in SP2 with data execution prevention (DEP). This precents code execution in memory regions already marked as storage. This is a powerful tool against buffer overrun exploits. If a program is failing and you want to disable DEP to see if that is the cause. Here are the steps. (Just disable DEP for the program in question… don’t disable it for your whole system.)
    1. Click Start
    2. Select Control Panel
    3. Select System
    4. Click the Advanced tab
    5. In the Performance region select Settings
    6. Click the Data Execute tab in the dialog box that opens
    7. Select Turn on DEP for all programs and services except for those I select
    8. Click Add.
    9. The open dialog box will open. Browse and select your application.
    10. Click Open
    11. Click Apply
    12. Click Ok
    13. Reboot
May 10, 2009 | Microsoft Internet Explorer 8
756 people viewed this tip
David Payne
David Payne
