Tip & How-To about Computers & Internet
Blu-ray vs HD DVD: State of the Belonging
Well, as far as HD DVD vs.Blu-ray goes, it looks like we've pretty much passed the point of no returnnow; with each passing day it seems less and less likely that a compromise willbe reached on a next-gen format. The ongoing peace talks between the two camps,which have been on-gain, off-gain for months now, seem to have finallydissolved. It's disappointing, but however you feel about the fact that the HDDVD and Blu-ray factions squandered countless chances to make it right and cometogether, it looks like in just a few short months they're going to be dukingit out mano a mano right in our livingrooms. There may not be a lot wecan do to fight back - apart from refusing to adopt either format out of sheerspite of their pigheadedness - but no matter what we might as well at least armourselves with the knowledge necessary to understand the nature of thesituation at hand. HD-DVD is now officially discontinued. However,information on HD-DVD, and its comparison to Blu-ray, is still contained inthis article for historical purposes, as well as the fact that there are stillmany HD-DVD player owners, and HD-DVD players and discs will continue to besold and traded on the secondary market for some time. In fact the differencebetween blu-ray and hd dvd is apparent. The Current StateOf DVD DVD isvery successful, and will definitely be around for some time. However as it isimplemented, DVD is not a high-definition format. DVD players typically outputvideo in either standard NTSC 480i (720x480 pixels in an interlaced scanformat), with progressive scan DVD players capable of outputting DVD video in480p (720x480 pixels displayed in a progressively scanned format). Although DVDhas superior resolution and image quality, when compared to VHS and standardcable television, it is still only half the resolution of HDTV. Blu-ray and HD-DVD Format Information However, there is a catch with regards to highdefinition DVD recording and playback; up until 2008, there has been twocompeting formats that were incompatible with each other. Blu-ray Format Support Blu-ray is supported on the hardware side byApple, Denon, Hitachi,LG, Matsushita (Panasonic), Pioneer, Philips, Samsung (also supports HD-DVD),Sharp, Sony, and Thomson (Note: Thomson also supported HD-DVD). On the software side, Blu-ray issupported by Lions Gate, MGM, Miramax, Twentieth Century Fox, Walt Disney Studios,New Line, and Warner. However, as the result of the discontinuation of HD-DVD,Universal, Paramount,and Dreamworks are now on board with Blu-ray. HD-DVD Format Support HD-DVD has been supported onthe hardware side by NEC, Onkyo, Samsung (also supports Blu-ray) Sanyo, Thomson(Note: Thomson also supported Blu-ray), and Toshiba. On the software side, HD-DVD has beensupported by BCI, Dreamworks, Paramount Pictures, Studio Canal,and Universal Pictures, and Warner (only until May 2008 - at which time it willbe Blu-ray exclusive). Microsoft had also lent its support to HD-DVD, but nolonger, as Toshiba has ended HD-DVD support. Read more blu ray related posts:
Computers & Internet Logo
I have a TT1620 but with the new HD antenna, I can not get the TruTech to find any channels.
Out of the several hundred reviews I've found on this product, exactly two gave it a passing grade. The vast majority of complaints were the flaky/useless tuner, and the flaky/useless DVD writer. The writer issue seems to be mitigated somewhat by using Memorex blank media. The tuner issue seems to be a design flaw. The only work around I've found has been to use the other inputs and use a cable or satellite box for tuning.
Sorry, but it sounds like you got one of the many duds. Wish I could offer more encouragement.
Jul 06, 2011 | TruTech TT1620 DVD Recorder
Is there a way to compress a 50Gb Blu-ray disk to a 25Gb Blu-ray disk(R or RE) without compromising too much quality?
For all DVD-Video and Blu-Ray backups or you existing Video Media I recommend using AnyDVD from Slysoft you can compress all Blu-Ray using this it will break the CSS and Region code you need to use another to re-encode the video.
I use Elaboratebytes CloneDVD to create an ISO image then use the excellent ImageBurn from Lightning to burn using VSO Patin-Couffin v1.37 Access Layer Driver for the best results.
You will need to select this after install in the I/O section
Jan 16, 2010 | Sony BDP-S300 Blu-Ray Disc Player
HD-A3 Movies Don't Play Video, but Menus are fine?
Might be a resolution issue, the menus are most likely in 480, while the video might be in a resolution not supported by your tv. Try changing the resolution and see what happens.
Jun 29, 2008 | Toshiba HD-A30 HD-DVD Player
PDV-722 Not Charging
perhaps find someone who knows how to work electronics and ask them if they can look at it?
Feb 08, 2008 | Durabrand PDV-705 Portable DVD Player
200 people viewed this tip
David Payne
David Payne
