Tip & How-To about Washing Machines
Maintain ur washing machine
Tricks to Keep Your Washing Machine Maintained
Water-fill hoses
Over time, the rubber water hoses that came with your new washing machine may leak or burst. It's a good preventive maintenance practice to check these hoses from time to time for any sign of wear or weakness. Often there's a small blister in the rubber of the hose, which could rupture. Most manufacturers recommend replacing the hoses every 5 years. An alternative is to replace the rubber hoses with high quality stainless steel fill hoses, which are more rugged.
Leveling
If your washing machine is not level, it can vibrate strongly during the spin cycle. If your washing machine is not perfectly level--with all four legs touching the floor--it can bang and rock back and forth, and even begin to "walk" across the room. This isn't good for the machine and may damage anything near the machine. Use the adjustable front and/or back leveling legs on the washer to adjust the machine to the proper height, then tighten the lock nut up against the body of the machine to keep the leg from rotating.
    • Most machines, however, have "self-adjusting" rear legs. You set these legs by tilting the entire machine forward onto its front legs (with the rear legs 3 to 4 inches off the floor) and then setting the machine back down. The legs should adjust automatically. If they don't, you may need to tilt the machine forward and rap on the rear legs with the handle of a hammer to loosen them--a procedure that's easier to accomplish with a helper.
Surface cleaning
Your washer has either a painted steel or porcelain-coated steel cabinet. It's perfectly safe to use a little dish detergent and a damp rag to clean all of its surfaces. If the surface is porcelain, you can even use a little non-abrasive cleanser for stubborn stains.
Washing Machines Logo
water sensor
common faults include the rubber pressure hose rubbing and a hole forming causing the pressure switch not to recognise the water level. un plug the appliance, take the top off, find the pressure switch and you will see a rubber black or clear hose running from what is normally a circular item approx 2" diameter and a hose running doen to the drum, check this hose for splits or tears.
Apr 10, 2014 | Washing Machines
kenmore water keep running will not wash
On many washing machines, there is a water level setting switch. This allow you to adjust the level in the machine to converse water. This switch works on air pressure. There is a small hose inside the outer drum at the bottom of the washer. It is connected to the pressure switch (level setting switch). As the washer fills, the weight of the water compresses the air in the hose until the pressure switch activates. There are two possible failure scenarios; they are both fairly easy to repair. First, the hose could be blocked at the drum entry point by lint or debris. This is a somewhat common occurrence. To check this, unplug the washer. Remove the rear cover from the control panel to access the rear of the switches. Find the rubber hose attached to the level switch and remove it. Blow through the hose to clear it. Reattach the hose and retest the machine. If that doesn't work, you may need to replace the water level switch, It is easily remove and replaced once you have accessed the rear of the unit. You can calls Sears service with the model and serial number of the machine and get replacement parts sent directly to your home.
Jan 01, 2012 | Kenmore Washing Machines
Fills cold and warm but not hot
This is a common problem with hot water lines to washing machines. The hose connecting the washing machine to the hot water supply has a small screen in the inlet of the hose. These are used to keep grit, etc from getting into the washing machine and causing bigger problems.
Here's what to do:
Pull the washing machine away from the wall a little so you can access the shut-off's. Turn off the hot and the cold water valves.
Take the hot water hose off the valve and check the screen in the rubber washer of the inlet hose. Replacement screen/washers are available at local hardware stores for a couple bucks.
You can clean the old ones, just be careful not to damage the rubber washer because that's what keeps your hose from leaking when you reinstall it on your faucet.
While you're at it, clean the cold water screen as well.
REcheck your fill on a hot cycle... you've most likely solved your issue!
May 09, 2010 | Washing Machines
Wash machine is filling with water when the washer is off.
You probably need to replace the water inlet solenoid valves which may be stuck open. Turn off one hose at a time to find out if both or just one is causing the problem.
Sep 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
water goes on to floor when filling washing machine. All hoses are connected securely.Machine was previously overloaded and shifted considerably when when nobody was home.
sounds like one of the hoses connecting drum or pump is adrift.most times these can be most readily seen with the machine lying on its back.make sure all power & water connections are off!
Aug 16, 2009 | Washing Machines
407 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
