Tip & How-To about Computers & Internet
How to install Windows using an SD card
Requirements
  • PC running Windows XP/2000 with a CD/DVD burner.
  • USB Flashdrive (Or some way to transfer files to the 3epc once Windows is installed)
  • SD Card, a fast SDHC is recommended of at least 2GB.
  • XP3eSD Utility
  • Hitachi Microdrive Filter Drivers
  • Partedmagic (or another bootable CD with disk cloning software)
  • Windows XP CD (SP2 Only Tested, may work with others)
Instructions:
  1. Copy all files from your XP Install CD to a folder on your Hard Drive
  2. Download the XP3eSD utility and run it to create a new install CD capable of installing Windows to boot off the SD card reader
  3. Boot your computer from the CD made in step 2
  4. Install Windows onto a FAT partition, deleting all the existing partitions
  5. When windows boots for the first time turn off the swap file, system restore, and the screensaver.
  6. Then stick your USB thumb drive into the computer with the Hitachi Microdrive Filter.
  7. Next copy the files from your thumb drive to the desktop and then properly remove the thumb drive.
  8. Unzip the microdrive files to a folder on the desktop. And Insert your SDHC Card into the computer
  9. You need to then Hit Start go to run, and type regedit. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USBSTOR\
    Inside that you should find a directory called something like Disk&Ven_USB2.0&Prod_CardReader_SD0&Rev_0100. Open it. Inside that you should find another directory wich is just a bunch of numbers. Open it. In the right pane you should see a key called "Hardware ID" Right click on it, and select modify. It should list about 7 lines of text. Copy ONLY the first line to the clipboard. Hit cancel, close regedit.
  10. Open cfadisk.inf in the directory you unzipped the microdrive filter to. Edit the section called [cfadisk_device] so that rather than containing 11 lines, just have one line. The line begins with: %MicroDrive_devdesc% = cfadisk_install,
    After the comma, hit ctrl V to paste what you coppied from the registry into the file then save the file.
  11. Go to Device manager. Under disk drives, you should see SiliconMotion and USB2.0 Card Reader. Right click on the card reader and click update driver. Direct the driver updater window to the Hitachi driver you just edited. It won't detect the driver automatically, you have to specifty that your supplying the disk for the hardware and force it to use the driver.
  12. Reboot using the Partedmagic CD or USB Flashdrive, Download it here
  13. Create a FAT32 partition on the SD card, same size as the one on the SSD in your computer
  14. Use 'fdisk -l' to find out the partition names of your SSD and SD.
  15. Type this command into a prompt: 'dd if=/dev/sda1 of=/dev/sdb1' When it finishes (it will take some time) type this command: 'dd if=/dev/sda of=/dev/sdb bs=512 count=1' (Note: If fdisk reported your SSD and SD as different than sda and sdb respectively, you must change that in the dd commands, if unsure ask in the support forums)
  16. When it finishes the task is complete, reboot and select to boot from the card reader
  17. Re-image the SSD of your computer with your restore DVD or USB.
Computers & Internet Logo
How to get the pc games to the removable disc(J) sandisk.Can not Move them to Flashdrive disc.
It is not completely clear if you mean large PC games or if you mean small PC games.
By small PC games I mean games similar to the games that come with Windows and that appear in the 'All Programs -> Games' folder. Such as 'Free Cell', 'Hearts' or 'Solitaire'.
By large games I mean games like 'World of Warcraft' or 'Mortal Combat'.
Also, do you want to install the games on your Flashdrive or store them there?
If you want to store a large game on your flash drive. Place the CD/DVD with the game on it in your CD/DVD drive and insert your Flashdrive in a USB port.
Open 'WIndows Explorer' or 'My Computer'. Locate the CD/DVD drive that you inserted the game disk in (most likely your D: drive).
In the 'Edit' menu select 'Select All' and then in the 'Edit' menu select 'Copy'.
Then locate the Flashdrive in 'WIndows Explorer' or 'My Computer'. And in the 'Edit' menu select 'Paste'.
While this will copy the files from your game's CD/DVD disk to your Flashdrive you may or may not be able to install the game from your Flashdrive.
You can use this same procedure to copy small games to your Flashdrive from your Hard Drive.
You will need to know where on your hard drive they are located. And they may or may not run from your Flashdrive.
Also you may be able to install and run games from your Flashdrive, When you run the Setup program from you game disk you will usually be given the option to select a alternative location to install the game.
Select your Flashdrive at that point and it may install correctly to your Flashdrive. If it does you should be careful to always use the same USB port or the game won't run.
Hope that helps.
Jul 04, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Hi, 1. How to transfer/copy bootable XP files onto SD card and then boot up Toshiba Portege M205 from the SD card? 2. Is it possible to made an image of my Windows XP CD on SD card? Regards Tad
Requirements
  • XP3eSD Utility
  • Asus Eee PC (Of course!!)
Instructions:
  3. Boot your 3epc from the CD made in step 2
  6. Then stick your USB thumb drive into the EEE with the Hitachi Microdrive Filter.
  8. Unzip the microdrive files to a folder on the desktop. And Insert your SDHC Card into the EEE.
  13. Create a FAT32 partition on the SD card, same size as the one on the SSD in your 3epc
  17. Re-image the SSD of your 3epc with your restore DVD or USB.
Jan 27, 2011 | Toshiba Portege M205-S810 Tablet PC
how can i reformat my asus eee pc1000h if it doesnt have a cd drive?
You can reformat your Asus eePC 100h notebook using an Ubuntu Live USB.Here is how to make one: 1. Download an Ubuntu ISO Disk image from www.ubuntu.com or a debian ISO image file from www.debian.com. 2. You can also use an existing Live CD to create an ISO Disk image with if you have a working PC around.Many free tools exist for creating disk images.I suggest Ashampoo Burning studio or CDBurnerXP.Search for them on google. 3.Get your hands on a working PC that has Windows XP/Vista/7 installed on it. 4. Download the UnetBootIn utility from http://unetbootin.sourceforge.net/unetbootin-windows-latest.exe. 5.The procedure for creating the Disk Image is as follows: (a)Requirements: 1 GB or larger USB drive, formatted as FAT32(most USB drives come formatted as FAT32 by default, but if you need to format it, on Windows, go to My Computer->right click your USB drive->format.
On Windows XP, you must be logged on as an administrator; on Windows Vista and above, you will be prompted for permissions via UAC.
On Windows, the UnetBootIN software looks like this:
Follow the guided prompts on the software to make your Live USB drive, and be careful to select the corrrect linux distribution on the window.
When done, safely remove the flashdrive from the PC and plug it in your Asus eeePC 100h notebook.
Boot up your notebook and press the F2 Key as the system starts up and select the USB flash drive as the first boot device(You can also do the same from the BIOS setup).
When you boot up with the Ubuntu Live USB, select "Try Ubuntu without installing" option to run the Live OS on RAM.
When the system boots up completely, go to System>Administration>Gparted and the Gparted Disk utilitty will run.
From the Gparted menu, select the appropriate partition you want to format or modify.
You can read more on Gparted here.
When you are done partitioning and formating your HDD as you desire, you can also install Windows XP/Vista/7 from a FlashDrive by following the instructions below:
1.Get your hands on a working PC with Windows XP/Vista/7 installed.
2.Download the WinToFlash utility from http://wintoflash.com/download/en/
3.Install the application on the PC.
4.Once you are done,insert a Windows XP CD in the PC's optical disk drive and follow the installation instructions from WinToFlash.
By default, the installation path for Windows XP files on the drive is DRIVE LETTER:/Windows/system32.
See the screenshot below for more details:
You can use the created bootable USB to install Windows XP on your notebook.
For more on WinToFlash, see this link:http://komku.blogspot.com/2009/09/wintoflash-guide-install-windows-xp.html
Have a great time ahead.
Jan 14, 2011 | ASUS Eee PC 1000H Laptop
installation cd/driver for wireless usb adapter for model# bwu613
I found a driver for you, link at the bottom...
Details Applies to: Blitzz BWU613B USB Wireless LAN Card Software/Application/PC Requirements: Windows XP, Windows XP, Windows 2000, Windows 98, Windows ME, Linux, Mac
Author: Blitzz Technologies
File Name: BWU613B_USB_Driver.zip
File Size: 7.51 MB Driver Date: 11/8/2003 Driver Version: ver. 1.3
http://rapidshare.com/files/273011370/BWU613B_USB_Driver.zip
Aug 29, 2009 | Dell Computers & Internet
installing cd/dvd games on acer aspire one a110
Get an external CD/DVD drive (USB) and run the game from that. (It's probable that you are hitting a copyright lock that needs the original disc.)
(if you want a DVD burner, you'll pay extra. Generally, the CD-RW/DVD-ROM drives are fairly cheap now <$50.)
Jul 02, 2009 | Acer Aspire One A110-1831 Notebook
351 people viewed this tip
David Payne
David Payne
