Tip & How-To about Car Audio & Video
How to find out what the polarity is on a speaker that you cant get too
Say your doing a car install and the speaker wires arent marked with a positive or negative symbol and you cant get to the back of the speakers or/and it would take a lot of extra time to take the doors apart so you can get to the back of the speakers,all you simply have to do is take the two wires coming from the speaker,grab any AA battery and put one wire on the positive side and the other wire on the negative and as your doing this observe the speaker and see if the speaker is sucking in or out.If it flexes out,then that is right and whatever wire is on the positive of the battery is your positive of the speaker and naturally the other one is negative.If the speaker flexes in then that is wrong ,just switch the wires and that will let you know which is which-Have Fun and Always unhook your battery when doing install-Thanks Steve
Car Audio & Video Logo
2008 dodge ram speaker polarity
Here is the radio wiring.
2008 Dodge Ram 1500 Car Stereo Install Instructions
Car Radio Battery Constant 12v+ Wire: Gray/Red
Car Radio Ground Wire: Black
Left Front Speaker Positive Wire (+): Dark Green/Yellow
Left Front Speaker Negative Wire (-): Dark Green/Light Blue
Right Front Speaker Positive Wire (+): Gray/Yellow
Right Front Speaker Negative Wire (-): Gray/Light Blue
Left Rear Speaker Positive Wire (+): Gray/Light Green
Left Rear Speaker Negative Wire (-): Gray/Dark Green
Right Rear Speaker Positive Wire (+): Dark Green/Gray
Right Rear Speaker Negative Wire (-): Dark Green/Light Green
Jul 14, 2017 | Cars & Trucks
HOW DO THE WIRE GO ON A2003 SIVERADO
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Red
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Red/Black
Car Stereo Amp Trigger Wire: Pink (also known as the remote wire)
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Here is the installation manual for your particular deck. Click Here. The first thing you should focus is getting the unit to power on. Follow the diagrams and you should be fine. Once you get your deck to power on then you can move on to the speakers. I tried to provide as much info as I can. Let me know if you need anymore help
Jan 28, 2012 | Eclipse AVN5435 Car DVD Player
car front two speakers arent working. rear two are.
have the front speakers ever worked?
if not have they been connected properly?
if yes then
look under ballance and check theat rear and front ballance is in the middle
if it is then for temporarily replace the front speaker with any old speaker
if that works then you need new front speakers
if no then the radio is broken
but what you could do is rewire the back speakers so they also play though the front ones too
this can be done from behind the radio
find the rear right positive and negative wires
strip the insulation but dont cut the copper wire
cut the front right speaker and attach that to the rear speaker wire
do this for both positive and negative
rear right
positive
..v
..v
I...I
I...I
I...I
.I.I..........< strip cable but do not cut metal
.I.I..______________
.I.I=_______________ <<<front right positive
.I.I
I...I
I...I
I...I
I...I
Jan 06, 2010 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
im changing factory radio to jvc and cut wires which ones are power source
here is a wiring color break down.
1987 Lincoln Mark VII Car Radio Wire Guide
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Orange/Blue
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): Pink/Blue
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Blue/Orange
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
please rate my help.
Jul 26, 2009 | 1987 Lincoln Mark VII
2,375 people viewed this tip
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
