Tip & How-To about Creative Labs ZEN V Plus MP3 Player
Creative Zen V Plus Bookmarks
A little known feature on this player is the ability to use bookmarks, up to 10 of them. Many of you listen to podcasts or audio books which may be fairly lengthy and if you have to stop in the middle of what ever you're listening to, normally when you go back to your player you would have to start all over again.
A note about "resuming playback": If you shutdown during playback of a podcast or audio book (not pausing or stopping playback first) your Zen will automatically resume playback when you start it back up.
Zen V Plus Bookmarking
You can insert bookmarks during playback. A bookmark helps you mark a point within a track, so you can return to it at a later time.
You can use up to 10 bookmarks at any one time.
To insert a bookmark:
  1. In the Now Playing screen, press the Options button and select Set Bookmark .
  2. For ZEN V Plus, you will need to press and hold the Options button. Playback pauses and the Set Bookmark screen appears.
  3. Select a bookmark number.
  4. Your bookmark is assigned to the selected bookmark number. If all 10 bookmark numbers have been assigned, you can replace an existing bookmark with the new one or you can delete a previous bookmark.
To delete a bookmark:
  1. Press and hold the Menu/Back button. The main menu appears.
  2. Select Music Library and then Bookmarks .
  3. Go to the bookmark that you want to delete.
  4. Press the Options button. For ZEN V Plus, you will need to press and hold the Options button.
  5. Select Clear Bookmark.
To go to a bookmark:
  1. 1. Press and hold the Menu/Back button. The main menu appears.
  2. 2. Select Music Library and then Bookmarks .
  3. 3. Select the bookmark that you want.
Note: The Bookmark feature is not applicable for contents played from the memory card for players such as ZEN 2GB,4GB,8GB,16GB, 32GB and the ZEN X-Fi Series. ZEN Xtra also supports bookmarks though you cannot place two or more bookmarks for one song or audio book
Creative Labs ZEN V Plus MP3 Player Logo
Can you add a bookmark?
How to use the GoGear bookmark feature in Audio books:
Adding a bookmark
  • During play, press "Option" button.
  • Select "Bookmark".
  • Select "Add bookmark".
  • Press "Play" button to save bookmark.
Accessing a Bookmark
  • Select "Go to bookmark".
  • Select bookmark from the list you want.
  • Press "Play" button to play the selected bookmark.
Removing a Bookmark
  • Select "Delete bookmark".
  • Press "Play" button to delete the selected bookmark.
Oct 10, 2013 | Philips Gogear SA2RGA04KS Mp3 Video Player
what is podcast
A podcast (or netcast) is a series of digital media files (either audio or video) that are released episodically and often downloaded through web syndication.
The mode of delivery differentiates podcasting from other means of accessing media files over the Internet, such as direct download, or streamed webcasting. A list of all the audio or video files currently associated with a given series is maintained centrally on the distributor's server as a web feed, and the listener or viewer employs special client application software known as a podcatcher that can access this web feed, check it for updates, and download any new files in the series. This process can be automated so that new files are downloaded automatically. Files are stored locally on the user's computer or other device ready for offline use, giving simple and convenient access to episodic content. Commonly used audio file formats are Ogg Vorbis and MP3.
Academics at the Community, Journalism & Communication Research group at the University of Texas at Austin in the USA are proposing a four-part definition of a podcast: A podcast is a digital audio or video file that is episodic; downloadable; programme-driven, mainly with a host and/or theme; and convenient, usually via an automated feed with computer software.
Go to www.podcast.com and look around
May 20, 2010 | SanDisk Sansa Fuze MP3 Player
bookmark
According to RCA you have to get a particular udiobook download. There was a free trial from somewhere in my origional package and that was the correct place for bookmarking.
Sep 04, 2008 | RCA OPAL M4001 MP3 Player
Fast Forward
http://serviceman.site88.net/index_files/MP3Players.htm
Jul 31, 2008 | Creative Labs Zen Touch MP3 Player
Bookmarking
you mean stop in the middle of a track and pick up where you left off? No....no such technology exists for MP3 Players.
Feb 05, 2008 | RCA TH1101 MP3 Player
1,357 people viewed this tip
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
