Tip & How-To about Computers & Internet
Did You Know? (#1: When Something isn't Working)
If you have a device that's connected to your computer and it's not working, you might think it's just broken. Odds are this isn't the case. If it's not working, try this:
- Click on Start - Click on Control Panel - Double-click on Device Manager
Uninstall the component that isn't responding by right-clicking on it and selecting Uninstall, then reboot your computer. If it still isn't working, go to the manufacturer's website and reinstall the latest drivers.
Also, if your device is wireless, it could just be that the battery needs to be replaced.
Computers & Internet Logo
lacie hard drive safe rugged usb connection broken
The USB connector would need to be replaced and soldered, in order for the device to work, some computer stores carry them because they have many applications.
Apr 17, 2012 | LaCie Computers & Internet
monitor will not boot up is reading no input signal
So either the computer isn't generating a video signal, the cable isn't carrying the signal to the monitor, or else the monitor isn't capable of receiving a video signal.To test this, first try a video cable that you know is good, in case your cable is bad, If it works with the other cable, the problem was your original video cable. If it still doesn't work, put your original cable back, and hook another computer up to the monitor. If the monitor makes the same message, the problem is with the monitor. If the other computer works when connected to this monitor, your problem was that the original computer isn't booting (which could be due to several reasons I will list below), or the video adapter is broken.Possible reasons for the computer not booting: bad power supply, bad power button, bad hard drive, bad memory, bad motherboard component. If you determine that it isn't booting, unplug everything except the keyboard mouse monitor and power cord, to see if that makes a difference. If it boots after that, something you unplugged was causing the problem, plug them each back in one by one, rebooting in between, and when it stops booting properly, the last thing you plugged in is causing the problem.
Mar 02, 2012 | Acer Computers & Internet
When I go to open a message using the adobe reader, it says it is unplugged
Each browser manages how they interconnect with other software on your system. The browser your using is giving you an error that say's "you need a plug-in" this really means your browser is not finding the connection (internally on your system) to adobe reader program. If adobe reader is installed and works opening a PDF that isn't on the internet. Then we have an association issue.
The odds are you don't have the proper program installed in which case I would start here.
May 11, 2011 | Computers & Internet
My kyros won't charge
I would first try a different power cord/brick and make sure that isn't the issue. If that still doesn't work then you may have a broken port on your Kyros. In that case try and get a warranty replacement and if that isn't feasible you will most likely have to pay for the repair. If you recently dropped it while it was plugged in, that may have broken the connection between the port and the device.
May 04, 2011 | Coby Kyros 716829701508 Tablet PC
a small device that connects to the hard drive is broken, so the pc can't boot up
in every computer need hard drive for storing data and software date in your case which device your trying to connect is must know and then in your question is not clear which one is broken any way listn my answer
in case of hard drive broken then need to replace new hard drive other wise device broken then no need to worry you must place device in front usb port or back usb port
in case of your hard drive is good then you needt to restart your computer and then press F5 continously that will help to open your pc
Feb 22, 2011 | Gateway 510 X (10272197) PC Desktop
162 people viewed this tip
David Payne
David Payne
