Tip & How-To about Cell Phones
How To Fix Your G1 Stuck On The Android Logo
First, if you haven't already tried it, please remove and re-insert the battery.
The following method erases all data from the handset's memory, and sets it back to original factory settings. It does not erase the sim card or the memory card.
There are two ways to perform a Factory Data Reset, also known as a master reset or hard reset. Since we cannot boot into the device, we will perform a hard reset:
  1. The device must be powered OFF to perform this reset.
    Note: If the device is not responsive and does not turn off, remove the battery and re-insert it.
  2. Press and hold the Home button (picture of a house on it) and the Power button (the red hang-up button) at the same time.
  3. Keep holding Home and Power together for at least 25 seconds, even if the "Startup" screen appears.
  4. Release the keys when you see a black screen with a warning sign.
  5. Slide the keyboard open.
  6. As a shortcut, press ALT+W to factory reset the device. If this does not work, continue with the below steps.
  7. Press ALT+L.
  8. Press Alt+W for 'wipe data/factory reset'.
  9. Press the Home + Back key.
Cell Phones Logo
i am able to send txts but the only ones i can receive are from vodafone. I sent one to myself last night & haven't received it. This problem was discovered when i got a call as i hadn't replied to a txt.
Please check the following steps
* Erase/delete messages and other unused data to preserve your phone memory space and to be able to use your phone without any problems.When your memory is too low,you can not be able to send,received messages and also you can't use the phone features such as taken photos or recording videos.all applications and other stuffs should be stored on memory card.
* try to use another phone and use your simcard,check if the problem is still the same.
* go to settings > master reset > reset all (back up your necessary data before doing this method,everything will be deleted if you continue and your phone will go back to default settings).
Hopimh that this solution will help.
Jun 16, 2011 | Motorola Mobility RAZR V3i Cellular Phone
i forgot my phone password
this happens all the time with samsungs. i went to tmobile.com/forums and found some info to fix mine when i forgot mine as well lol. the problem is it will reset your password and all your other information as well :(
A phone lock or security code on most Samsung handsets can be overridden by performing a full reset on the device. This will set the security codes on the handset back to the default eight zero's (00000000).
Important: This reset restores the original factory settings and will erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. It does not erase data stored on the SIM card or memory card (if available). Make sure you have backed up contacts, calendar appointments, and other data before continuing.
1. Power off the handset
2. Remove the battery
3. Remove the SIM card
4. Reinsert battery ONLY
5. Turn handset on
6. At the Insert SIM prompt screen enter the following code: *2767*2878#
NOTE: If using a handset that was released after July 2009 use this code: *2767*3855#
7. The handset should display E2P custom reset
8. Power off handset
9. Reinsert SIM card
10. Power on handset
11. The phone should be unlocked
NOTE: If you didn't get a E2P custom reset or a Full reset message on the handset your Samsung model may need an MCK code. You will have to call technical support for this code. Please have your IMEI number ready to expedite the process for this code. Your IMEI number is located on a label on the back of the phone,under the battery.
Dec 24, 2010 | Samsung C3510 Cell Phone
my sister forgot the password to her phone
im sorry about that! the problem is all your info will be lost. you need to enter the following steps which will reset your code, but will also reset your phone and information. i found this at t-mobile.com/forums.
5. Turn handset on
Dec 24, 2010 | Samsung UpStage SPH-m620 Cellular Phone
i have tried calling *22899 to unlock my samsung schu350 and it didnt work it locked automatically when its turned on how do i unlock it
i found some great info but it will automatically delete all your info as well. i found this at t-mobile.com/forums but its universal on all samsungs
5. Turn handset on
Dec 24, 2010 | Samsung Smooth SCH-u350 Cell Phone
i have a samsung solstice SGH A887 and i bought the phone and it already had a security code set On it and i can't figure out what my security code is. i tried everything.
no worries it happens alot infact it happened to me on my samsung as well lol! its a quick fix but it will delete all your info:( i found the info at tmobile.com/forums but its universal on ALL samsungs!
f your Samsung handset has a security code or phone lock on it follow these steps to disable the code.
NOTE: This code is not used for Subsidy unlocks, Application Locks or PUK (PIN) code lock outs. Call Customer care for these.
5. Turn handset on
Dec 24, 2010 | Samsung Solstice SGHa887
847 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
