Tip & How-To about Computers & Internet
Non-System disk or disk error
Issue:
Cause:
The current media is not bootable or there was a disk error in attempting to boot.
Workaround:
1. Change Boot Media
If you are booting from either a DVD, CD, diskette or a USB drive, remove the media and boot from the hard disk. The media is either damaged or is not intended to be bootable.
2. Set the Correct BIOS Boot Choice
The BIOS may be configured to boot from the wrong device. If you suspect this, the device boot order can be changed in the BIOS setup. Be aware there little consistency in BIOS setup operations, even with the same manufacturer on different models. As such, these instructions are bit less precise than we'd prefer.
Reboot and enter the BIOS setup. Often the BIOS displays the correct key to use briefly on screen or you may need to refer to the computer's user manual. Typically you hold down the Del, Esc, F1 or F2 key immediately after booting.
Look for a section on Boot or Booting. Often this appears on top menu. Select the Boot option, and if necessary the Boot order choice. The Boot order choices should list the order of boot devices. Typically the CD is the first boot device with the hard-disk typically second. The diskette may also occur before the hard disk, which is acceptable, although this will slow your hard disk boot by a few seconds. Avoid USB and network boots before the hard disk unless you know for sure you are using them (which is exceptionally rare).
Save and exit the BIOS. It will force a reboot. See if this change corrects the issue.
3. Check Hard Disk and Cables
If you had changed, added or removed hard drives, or changed or removed drive cabling, likely something is wrong. Recheck that the drives are properly installed and the cabling has not changed. Switching cables to different motherboard connectors or changing the master/slave drive jumpers (on old ATA drives) can cause this problem. In some systems, the cables were not plugged into the drive or motherboard securely and may have worked loose. Reseat all drive connectors.
It's also possible a hard drive is failing. Use a system diagnostic to validate the drive or swap to another hard disk.
Hope it helps,
Thank you for using FixYa
Best regards,
Reyjoshua07
Computers & Internet Logo
non;system disk or disk error
This issue may occur if your start device (such as a floppy disk drive, hard disk drive, or CD-ROM drive) does not contain boot files.
To resolve this issue, use one or more of the following methods, and then restart your computer:
  • Remove the non-system disk from your boot device. For example, remove the non-system disk from the floppy drive or the CD-ROM drive.
  • Change your computer's boot sequence. To do this, you must change your computer's setup and the option that controls which device your computer uses to start from. Make sure that you select a device that has boot files (or operating system files) installed.
  • If you start your computer from a hard disk drive, install a bootable operating system (such as Windows XP) on the drive.
site: http://support.microsoft.com/kb/812492
I hope this helped!
Please don't forget to vote!
Sep 05, 2009 | Compaq Armada E500 Notebook
"Non-system disk or disk error replace and strike any key when ready".
If this error occurs you open the cabinet disconnected the harddisk data cable for few seconds and reconnected the harddisk data cable and bot it will work.
Apr 10, 2008 | Compaq Evo N610C Notebook
Media Test Failure, Check Cable.....
This is an Invalid / Non System Disk error.In your Bios settings change the "First boot device" option to your hard disk.If you have only one hard disk set it to "HDD 0"
Other causes of the problem are:
  1. Floppy or CD that is not bootable is currently in the computer.
  2. Hard disk's power or data cable is not connected properly(loose contact)
Oct 12, 2007 | Acer Aspire L310 (ASL310UD631A) PC...
1,601 people viewed this tip
David Payne
David Payne
