Tip & How-To about Computers & Internet
Fatal issue: Error loading operating system
Issue:
Cause:
The MBR (Master Boot Record) either could not find a bootable partition or the bootable partition points to an unreadable on inaccessible part of the drive. This issue occurs prior to the start of any Windows code.
It can be caused by a power-failure while the disk is in the middle of writing, a virus damaged the entry, a failing disk drive or a serious software bug damaged the partition entry (although Windows typically protects against this). This issue cannot be easily caused by any action you performed, unless you turned off the power without going through Windows shutdown.
Although not stated in the message, press Ctrl-Alt-Del to reboot.
Workaround:
Change boot media:
If you are booting from either a DVD, CD, diskette or a USB drive, remove the media and boot from the hard disk. The media is either damaged or is not intended to be bootable.
Set the Correct BIOS Boot Choice:
The BIOS may be configured to boot from the wrong device. If you suspect this, the device boot order can be changed in the BIOS setup. Be aware there little consistency in BIOS setup operations, even with the same manufacturer on different models. As such, these instructions are bit less precise than we'd prefer.
1. Reboot and enter the BIOS setup. Often the BIOS displays the correct key to use briefly on screen or you may need to refer to the computer's user manual. Typically you hold down the Del, Esc, F1 or F2 key immediately after booting.
2. Look for a section on Boot or Booting. Often this appears on top menu. Select the Boot option, and if necessary the Boot order choice. The Boot order choices should list the order of boot devices. Typically the CD is the first boot device with the hard-disk typically second. The diskette may also occur before the hard disk, which is acceptable, although this will slow your hard disk boot by a few seconds. Avoid USB and network boots before the hard disk unless you know for sure you are using them (which is exceptionally rare).
3. Save and exit the BIOS. It will force a reboot. See if this change corrects the issue.
Check Hard Disk and Cables
If you had changed, added or removed hard drives, or changed or removed drive cabling, likely something is wrong. Recheck that the drives are properly installed and the cabling has not changed. Switching cables to different motherboard connectors or changing the master/slave drive jumpers (on old ATA drives) can cause this problem. In some systems, the cables were not plugged into the drive or motherboard securely and may have worked loose. Reseat all drive connectors.
It's also possible a hard drive is failing. Use a system diagnostic to validate the drive or swap to another hard disk.
Computers & Internet Logo
what is MBR in dos
MBR stands for Master Boot Record
During the booting process MBR points the system from which partition it has to load the operating system
Mar 13, 2013 | HP Pavilion Computers & Internet
trying to restore to factory settings. i pressed f8 but option "repair your computer isnt there"
try cntrl + F11 at start up
WHAT CAN CAUSE PC RESTORE TO FAIL?
If the hidden DSR (Dell System Restore) partition is removed
If the MBR (Master Boot Record) is modified in any way (such as if you load the Vista Upgrade over XP)
If you change the MBR but the pointers to the DSR partition are left, the DSR will boot, detect that the MBR has changes, and flash a screen that informs you that the MBR has changed and that image restore will not run
If you create additional partitions, changing the MBR, Dell PC Restore will be disabled to prevent it from overwriting these partitions that may contain critical data during a restore operation
If you add a second SATA drive and migrate to a RAID array using the Intel applications accelerator in windows, running PC Restore will put the image back on C:\, but the system will not boot since the boot sector is looking for the ATA driver (factory image) and the bios is looking for the RAID driver (migrated configuration)
If any of these occur, you cannot set the system back to Factory condition. You must manually load the operating system, drivers, and all application software.
Mar 27, 2012 | Dell XPS 410 PC Desktop
error occured in toshiba satelite 1300 in the hard disk code 0101340000
Error code 0101340000, may be due to hardware issues
1. Faulty hard drive or defective memory
2. Damaged recovery media(CD) or faulty CD ROM
OR
Boot system corrupted,
This issue may occur if one or more of the following conditions are true:
The basic input/output system (BIOS) does not detect the hard disk.
The hard disk is damaged.
Sector 0 of the physical hard disk drive has an incorrect or malformed master boot record (MBR).
Note Some third-party programs or disk corruption can damage an MBR.
An incompatible partition is marked as Active.
A partition that contains the MBR is no longer active.
Hope it helps.
Aug 12, 2010 | Computers & Internet
370 people viewed this tip
David Payne
David Payne
