Tip & How-To about Computers & Internet
Fatal issue: Reboot and Select proper Boot device
Issue:
or Insert Boot Media in selected Boot device
Cause:
The boot record could not find a bootable partition so control was passed back to the BIOS. This issue occurs prior to the start of any Windows code.
It can be caused by a power-failure while the disk is in the middle of writing, a virus damaged the entry, a failing disk drive or a serious software bug damaged the partition entry (although Windows typically protects against this). This issue cannot be easily caused by any action you performed, unless you turned off the power without going through Windows shutdown.
Workaround:
1. If you had changed, added or removed hard drives, or changed or removed drive cabling, likely something is wrong. Recheck that the drives are properly installed and the cabling has not changed. Switching cables to different motherboard connectors or changing the master/slave drive jumpers (on old ATA drives) can cause this problem. In some systems, the cables were not plugged into the drive or motherboard securely and may have worked loose. Reseat all drive connectors.
2. It's also possible a hard drive is failing. Use a system diagnostic to validate the drive or swap to another hard disk.
3. If the first bootable drive is missing (disconnected or dead) the BIOS may be attempting to boot from a second disk. Confirm the primary drive is working.
Hope this will help...Your response is very much appreciated...
Computers & Internet Logo
My question is that when I switch on my AsusX5DC it displays "Reboot and Select proper Boot device or Insert Boot Media in selected Boot device and press a key" Am lost. how do I reboot it?
Enter the bios. Set the first boot device to your bootable hdd or USB/DVD drives if you are reformatting and starting again with an OS.
Jun 07, 2016 | Computers & Internet
My pc wont boot. All i get is " reboot and select proper boot device or insert boot media in selected boot device and press a key"
This can happen if you have non-bootable media in the default boot device (i.e., you have a CD in the CD/DVD drive and that drive is listed as the default boot device in your system's BIOS). More often (on newer systems), a failed hard drive will also produce this message.
If you have bootable media (the Windows install CD is one example), you should try to boot to it and see if you can read your hard drive.
Jan 20, 2014 | Computers & Internet
my hp mini is showing Reboot and select proper boot device or insert boot media in selected boot device and press a key
Insert a Bootable Opearating system CD
Reload Your Operating System if Problem persist change your hard disk
Load the Operating System
Dec 21, 2010 | HP Mini 1000 Netbook
439 people viewed this tip
David Payne
David Payne
