Tip & How-To about Dishwashers
Resolve Intermittent Drain in Dishwasher
From the excellent description you give the most likely cause of this problem is the check ball and funnel in the soil collector.It drains fine sometimes but sometimes it doesn't drain but the motor is turning. If the motor is turning in the drain cycle most likely the motor and timer are okay. The motor on this dishwasher runs one direction to wash and one direction to drain. You can listen for this but there is another more likely part causing this problem.
The idea is that in the wash cycle the circulation of the water brings food particles into the chamber. In the drain cycle the circulation is reversed and the check ball is suppose to seal the funnel off so all of the food and soils go down the drain. If the check ball doesn't seal the funnel then the water will not drain but go back into the tub.
Most likely your problem is with the check ball and/or funnel. There may be something in the chamber preventing the check ball from sealing the funnel all of the time. Sometimes it does but sometimes it doesn't.
The images below will give you an idea of where the soil settler is located. You can remove the toe panel but must likely you'll need to pull the dishwasher out to access it.
This is a job I'd recommend a technician do. The funnel , check ball and the soil settler/separator . You will also need some RTV sealant but even technicians have difficulty with this repair and I suggest you let the technician get the headache.
The check ball and funnel can definitely cause an intermittent drain problem.
I hope this information is helpful resolving this problem.
Dishwashers Logo
water in refridgerator compartment
It would be helpful if you could give the make and model of your refrigerator. But with some fridges there is a funnel at the back under the freezer. It is connected to a plastic tube that runs down the inside of the back of the fridge. When that tube becomes blocked, it causes water to overflow the funnel.
If you find that this little funnel has water in it, here is the solution: You can usually find a very long pipe-cleaner (about yon yard or one meter) at specialty stores. Remove the funnel, take the pipe cleaner and ream the pipe. Replace the funnel and that should solve your problem.
If your fridge does not have this drain, then there are other possible causes. To really tackle this properly we would need to know the make and model. Cheers.
Apr 16, 2014 | Whirlpool Refrigerators
Water leak from Electrolux Kelvinator EPK09CRN2A portable air conditioner
You'll have to open it up and check for a displaced condensate collector. This may look like a funnel with a drain tube that is supposed to go to the tray
Nov 28, 2012 | Electrolux E23CS75SS Air Conditioner
There is water dripping filling up the bottom under the salad container. The model is a LRTN22311TT.
Remove contents of fridge and check the drain line running down the top back of the back of fridge and follow to lower section of fridge (usually a back ledge or under the crisper sections) and locate a small round drain hole. Also, check to see that the drain collector (funnel looking thing at top back of fridge section) is located under the freezer defrost drain opening, to allow water to flow through the fridge into the drain pan under the fridge.
If something has obstructed the drain funnel, path, tube, or lower drain hole, remove the blockage to allow water to drain into underneath of fridge into drain pan for proper evaporation of water produced from the usual daily defrost cycle of fridge/freezer.
If that is not the problem, it could be that you have a leaking water supply line for your ice maker and you'll need to see if the freezer is allowing excessive water to flow out of the ice maker into the fridge section.
Another simple check/solution is that the fridge is not properly leveled, meaning that the front of the fridge should be slightly higher than the rear to allow for proper drainage and self closing of the front doors. This will help keep the water flowing in the built in channels and drains.
A perfectly level fridge isn't the right way to install most moveable refridgerators, while built in fridges (Sub Zero, etc.) are designed for plumb and level installations for proper functioning and use.
Apr 09, 2009 | LG LRTBC1825T Top Freezer Refrigerator
490 people viewed this tip
Top Dishwashers Experts
