Tip & How-To about Computers & Internet
No Display In Motherboard
Hi,Thanks for using fixya,
Switch off the computer and open the pc cover.
First check the ram,and clean by eraser or with solvent and install again.If the problem is same, install the ram to another computer to ensure either it damage or not .If the problem is same change ram.
http://en.wikipedia.org/wiki/DIMM
http://www.pcbuyerbeware.co.uk/RAM.htm
If same as before, remove the cmos battery or clear the cmos jumper and hold" on off "switch for 40 seconds. Install battery again and start pc.
Now please check the "smps" by another new or by your"smps" to another pc to confirm either it damage or not.
http://www.playtool.com/pages/psuconnectors/connectors.html
If same as before now please take a risk and ready to chip label repair,
1.Change all the bad capacitors, beside the processor, with the help by nearest technician. http://cquirke.mvps.org/badcaps.htmhttp://en.wikipedia.org/wiki/File:Acer_E360_Socket_939_motherboard_by_Foxconn.svghttp://en.wikipedia.org/wiki/Motherboard
2. Set an identification Mark, on the bios chip, by the permanent marker because you need to remove and install it. It could not be possible for all mother board.
3. Remove bios chip from base, clean with solvent and install it proper again.It could not be apply for all mother board.ONLY FOR INTEL PLATFORM
4.For Intel mother board ,install a floppy drive and switch on the power and, watch the "led light",( floppy drives )either Blink with a long times or not.
If the floppy drives led light on, download updated bios your Intel mother board,and use a floppy disk for restore the bios , Download link.http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22865%22.
5. Don't switch off your motherboard at the time of updating the bios, so please use ups and insert the floppy, along with bios file. Set the cmos jumper in recovery mode (just change the normal position). http://www.intel.com/support/motherboards/desktop/sb/cs-023360.htmhttp://www.intel.com/support/motherboards/server/s5520ur/sb/CS-030161.htmNow switch on motherboard, hope, through these processes,should recover the mother board.
If the problem is same, try to install a graphics card. For same problem I will recommend you for new motherboard.
Hope this helps,.
Thanks for using fixya.
Computers & Internet Logo
not display image
Switch off the computer and open pc cover.
First check the ram, clean by eraser or with solvent and install again, if theproblem is same install the ram to another computer either it damage or not .Ifthe problem is same change ram.
If same as before, remove the cmos battery or clear the cmos jumper andhold" on off "switch for 40 seconds. Install battery again and startpc.
Now please check the "smps" by another new or by your"smps"to another pc to confirm either it damage or not.clip_image001.gifclip_image001.gifclip_image001.gif
http://site7.way2sms.com/jsp/Main.jsp?id=6BEFB035C72C9BC7795F7E8D4A2E60B9.a403
1.Change all the bad capacitors, beside the processor, with the help by nearesttechnician. http://cquirke.mvps.org/badcaps.htmclip_image001.gifhttp://en.wikipedia.org/wiki/File:Acer_E360_Socket_939_motherboard_by_Foxconn.svgclip_image001.gifhttp://en.wikipedia.org/wiki/Motherboard
2. Set an identification Mark, on the bios chip, by the permanent markerbecause you need to remove and install it. It could not be possible for allmother board.clip_image001.gifclip_image001.gifclip_image001.gifclip_image001.gif
3. Remove bios chip from base, clean with solvent and install it properagain.It could not be apply for all mother board.ONLY FOR INTEL PLATFORM
4.For Intel mother board ,install a floppy drive and switch on the power and,watch the "led light",( floppy drives )either Blink with a long timesor not.
If the floppy drives led light on, download updated bios your Intel motherboard,and use a floppy disk for restore the bios , Download link.http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22865%22.
5. Don't switch off your motherboard at the time of updating the bios, soplease use ups and insert the floppy, along with bios file. Set the cmosjumper in recovery mode (just change the normal position). http://www.intel.com/support/motherboards/desktop/sb/cs-023360.htmhttp://www.intel.com/support/motherboards/server/s5520ur/sb/CS-030161.htmNowswitch on motherboard, hope, through these processes, should recover the motherboard.
If the problem is same, try to install a graphics card. For same problem I willrecommend you for new motherboard.
Hope this helps,.
Feb 22, 2011 | Computers & Internet
video problem
Now please check the "smps" by another new or by your"smps" to another pc to confirm either it damage or not.clip_image003.jpgclip_image004.jpgclip_image005.gif
1.Change all the bad capacitors, beside the processor, with the help by nearest technician. http://cquirke.mvps.org/badcaps.htmclip_image007.jpghttp://en.wikipedia.org/wiki/File:Acer_E360_Socket_939_motherboard_by_Foxconn.svgclip_image009.jpghttp://en.wikipedia.org/wiki/Motherboard
2. Set an identification Mark, on the bios chip, by the permanent marker because you need to remove and install it. It could not be possible for all mother board.clip_image011.gifclip_image012.gifclip_image002.gifclip_image013.gif
Hope this helps,.
Feb 18, 2011 | MSI K8MM-V Motherboard
no dasplay
shibuda
  • Rank: Guru asus.gif computers_small.png
  • Rating: 98%, 1839 Votes
Hi,thanks for using fixya,
Switch off the computer and open PC cover.
First check the ram, clean by eraser or with solvent and install again ,if the problem same install the ram to another computer either it damage or not .If the problem is same change ram.
If same as before, remove the cmos battery or clear the cmos jumper and hold " on off "switch for 40 seconds. Install battery again and start pc .
Now please check the "smps" by another new or by your "smps" to another PC to confirm either it damage or not.shibuda_44.jpgshibuda_43.jpgshibuda_42.jpg
1.Change all the capacitors, beside the processor, with the help by nearest technician.
2.Set an identification Mark, on the bios chip, by the permanent marker because you need to remove and install it.It could not be possible for all mother board .
3.Remove bios chip from base , clean with solvent and install it proper again.
4.For Intel mother mother ,install a floppy drive and switch on the power and,follow the floppy drives "led light", either it glow or not.
If the floppy drives led light on,download bios file for your inlet mother board ,paste on floppy.follow the bellow link for download.
5.Now don't switch off your motherboard at the time of updating the bios,so please use an ups,and insert the floppy, along with bios file.Set the cmos jumper in recovery mode( just change the normal position ),and switch on motherboard, hope, through this process, should recover the mother board.
If the problem is same, I will recommend, you for new motherboard.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 23, 2011 | AMD Foxconn 6100K8MA-RS 6100 Mainboard...
i am not getting display. why?
First check the ram, clean by eraser or with solvent and install again ,if the problem same install thre ram to another computer either it damage or not .If the problem is same change ram.
Now please check the "smps" by another new or by your "smps" to another pc to confirm either it damage or not.shibuda_44.jpgshibuda_43.jpgshibuda_42.jpg
4.For Intel mother mother ,install a flopy drive and switch on the power and,follow the flopy drives "led light", either it glow or not.
If the flopy drives led light on,download bios filre for your intel mother board ,paste on flopy.follow the bellow link for download.
5.Now don't switch off your motherboard at the time of updating the bios,so please use an ups,and insert the flopy, along with bios file.Set the cmos jumper in recovery mode( just change the normal position ),and switch on motherboard, hope, through this proceses, should recver the mother board.
If the problem is same, I will recoment you for new motherboard.
Jan 23, 2011 | Asrock P4I45GV...
the motherboard won't give a response
Jan 20, 2011 | ASUS P4R800-VM Motherboard
434 people viewed this tip
David Payne
David Payne
