Tip & How-To about Computers & Internet
How to Remove Windows Vista Password?
To improve the Windows Vista security, entering the username and password is required by default firstly when users want to enter computer. In fact, if the computer is only used for you only at home, it seems no need to enter the password to do it. Entering computer without password may be the best choice. In this case, you can simply remove Windows Vista password based on the following three methods. By the way, the method 3 also can be used to reset Windows Vista password when you are locked out of computer.
Method 1: Remove Windows Vista password with Control Panel
Step 1. Click on Start, Control Panel.
Step 2. Click User Accounts and Family Safety, and then click the User Accounts link.
Step 3. Click the Remove your password link in the User Accounts screen.
Step 4. Enter your current password in the text box on the next screen, and then click Remove Password button.
Now that your Windows Vista password has been removed, you will be no longer need to enter password when you enter computer. In addition to the Control Panel, you can also remove the password with Computer Management. Then follow the method 2 below to remove the password.
Method 2: Remove Windows Vista password with Computer Management
Step 1. Right-click Computer and select Manage.
Step 2. Click Local User and Groups, and then click Users. And all the accounts will be listed for you.
Step 3. Right-click target account and select Set password.
Step 4. Leave the password text field blank and click OK.
The two methods above require you log on computer firstly. If you forgot Windows Vista password and are locked out of computer. These two methods could not help you. Then you need to try the method 3.
Method 3: Remove Windows Vista password with software
If the methods mentioned above don't work, the most efficient way is to take advantages of Windows Login Recovery. This software allows you to burn a password reset disk with a blank CD/DVD or USB flash drive. You can use the password reset disk to reset or remove Vista password. This method is often adopted when people are locked out of computer with all Windows administrator passwords lost.
Step 1. Download and install Windows Login Recovery in any computer.
Step 2. Burn a password reset disk with a blank CD/DVD or USB flash drive.
Step 3. Boot your locked computer from the created password reset disk.
Step 4. Reset Windows Vista password by following the instructions.
Windows Login Recovery is secure software. Your valuable data will not be lost when you remove password with this powerful Windows password recovery tool. If you think that the steps above are not clear enough, you could view the Windows Login Recovery User Guide.
The above three methods can help you remove Windows Vista password easily and safely. Even though you are completely locked out of your Vista computer, you can remove the forgotten password and log on your computer again.
Computers & Internet Logo
Can't get logged in on windows 8
Follow the steps:
Requirements:
1 ) Windows Vista or 7 DVD
1. Insert the Windows Vista DVD into the DVD drive and then restart the computer.
2. Change Boot Options 1st Priority to Optical Drive.
3. When system booting up, if the message "Press any key to boot from cd" appears, immediately press Enter.
4. On Language Settings, Time and Currency and Keyboard Layout screen, just choose the correct settings then click Next.
5. On Install Now screen, click Repair. Note: Click No just in case you get the message: Windows found problems with your computer's startup options.
6. On the System Recovery Options screen, under Operating System, click Windows Vista then click Next. Then select Command Prompt.
7. At the command prompt windows, type the following command then press Enter after typing each command:
c:
cd windows\system32
echo ~takeown /f %1 /r /d y > TakeControlOf.cmd
echo ~icacls %1 /grant administrators:F /t
ren Magnify.exe Magnify.old
ren cmd.exe Magnify.exe
8. Restart the computer.
9. On the Welcome Screen, click the Ease button.
10. Check Make items on the screen larger then click OK.
11. At the prompt, type the command then press Enter.
net user Administrator /active:yes
exit
12. Restart the computer.
13.
At the welcome screen, logon using the local administrator account.
14. Access Control Panel then click User Accounts. Select the username of the account you can't login to then remove the password.
15. Log off on the current local administrator account your are logon to.
16. Check if you can logon to your user account now.
17. Open c:\windows\system32.
18. Right click on Magnify.exe, select Properties -> Security -> Advanced -> Owner -> Edit -> Administrators then click OK.
19. Select Edit -> Administrators -> Full Control then click Apply then OK.
20. Rename Magnify.old to Magnify.exe
21. Open command prompt then type the command then press Enter.
net user Administrator /active: no
To create a new user :
Net user username/add
Windows XP/2003, Vista and Windows 7.
To add a new user account to the local computer from command line:
net user username password /ADD
Example: To add a new user account with the loginid John and with password fadf24as
net user John fadf24as /ADD
To add a new user account to the domain:
>net user username password /ADD /DOMAIN
Note that we do not need to specify the domain name here.
Example:
net user John fadf24as /ADD /DOMAIN
Rename a user account from windows command line
We can use below wmic command to rename a user account from command line.
wmic useraccount where "name='username' " rename new_username
Ex: To rename the user account techblogger as win7techblogger
wmic useraccount where "name='techblogger' " rename win7techblogger
Net use command does not have any switches to rename a user account.
Few more Advanced uses of net user command.
To specify user full name while creating the user account
net user username userpasswd /ADD /FULLNAME:"User_Fullname"
To specify that the user is allowed to change the password
net user username userpasswd /ADD /PASSWORDCHG:Yes
To restrict user not to change the password:
net user username userpasswd /ADD /PASSWORDCHG:NO
To specify when the account expires we can use /EXPIRES switch.
To specify if the user must have a password set we can use /PASSWORDREQ switch.
How to create a new administrator account from command line?
An administrator account can't be created directly from command line. We first need to create a user account and then add the user to the administrators group.
Errors:
If you don't have privileges to add new user account to the system, you would get an error like below.C:\>net user John /add
System error 5 has occurred.
Access is denied.
C: \>
if cant able underatand send me your mail id..
Nov 10, 2013 | Computers & Internet
windows security center
If this is your router and you've forgotten the username or password we suggest that the router be reset and then setup with a new username and password.
Default username and password
Before doing a hard reset on the router you may want to try the default username and password. While this is not the same for all routers, this may allow you access to your router.
Username: Admin or Administrator
Password: <Blank>, try just pressing enter or try "admin" as the password as well.
If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com
Sometimes when attempting to visit a secure website on your Windows computer, you will receive a message about a security certificate error.
You will have the option of whether to continue to the site.
Secure websites, such as an online bank or retail store, use security certificates so your browser knows that any financial or personal information you enter on the website will go the correct place securely.
Every error message does not necessarily indicate a security problem on the website.
Check your computer's date and time.
If they are incorrect, you will receive security certificate errors.
Click on the time in your taskbar, and set the correct time in the pop-up window.
Refresh the website where you received the error message.
If you receive a security certificate error message again, the problem lies with the website's security certificate.
Click the icon that looks like a padlock next to your browser's address bar.
Read the information in the window.
This will detail who owns the website, the site's verification status and any known information about the website's trustworthiness.
Compare this to what you know about the site you were attempting to visit.
Click "View Certificates, then "Install Certificates."
Click "Yes" at the security warning to install the certificate for the website.
May 20, 2013 | Linksys WRT Computers & Internet
need to change netgear router rp614 from dsl to cable
Hello
First connect one of the ethernet ports (LAN) to your computer.
In windows to this:
XP: Start -> Run -> write CMD and press ok-> Black window pops up-> write IPCONFIG and press Enter. -> Look for Local ethernet connection and write down the ip adress outside default gateway (f.ex 192.168.0.10 or 10.0.0.1).
Vista: click windowsmenu icon-> write CMD in search field and press enter -> Black window pops up-> write IPCONFIG and press Enter. -> Look for Local ethernet connection and write down the ip adress outside default gateway (f.ex 192.168.0.10 or 10.0.0.1).
Open a webbrowser and clear det adress field, enter the adress (with the dots and no www.) you wrote down from default gateway and press enter.
If you get promted for a username and password the default is: username: admin password: password (you can find it on the side of the netgaer box under deafult accsess.
If you cant get in try to do a "hard reset" (push the reset button for 30 sec with a pen).
You are now in the web user interface for you netgear.
On your lefthand side, you should have a blue menu, click on the first option on the top and run the setup wizard, dont change anything (dont choose that your connection needs a password to connect) just use the default settings. Remember to press save on the botom.
You should now be ready to use your netgear router.
If this guide didnt fix your problem, i need more details to help you.
Check with your new service provider if they require a username and password to connect (PPPoE).
Feb 07, 2009 | NetGear WGR614 Wireless Router
291 people viewed this tip
David Payne
David Payne
