Tip & How-To about Computers & Internet
Sylvania SYNET07526 Owners
For all owners of the Sylvania SYNET07526:
Do not fill in the "OWNERS PROPERTY BLOCK"
filling in this block of information with the Network ID, Password, and Domain will block your machine from connecting to the Internet.
To check this information, do the following:
Click on Start
Double click on Settings
Click on Control Panel
Double click on Owner
Click on Network ID Tab
If any information is in the blocks, remove and leave blank
click on X in the upper right corner to go back, click on start and shut down
Push the power button to start up. Note: holding the power button down for about five seconds ensures a start up . If you have trouble starting up.
Flip the machine over and find a small hole about 1in. diagonally from the right lower corner of the data plate. Insert the tip of a tooth pick into the hole and press down for about 10 second, with the AC power connected to the machine. It should re-load a fresh copy of the operating system
To populate the WiFi with password information.
Double click on the WiFi icon down in the right corner tool bar, it looks like a small computer with two small arcs radiating out to the side. If it has a red X under it, this means you are not connected to the internet.
When you double click on that icon a window opens up named RT701. look to see if the fields are filled in.
Address Type: DHCP
I.P.Address: 192.168.1.(2,3,4...your device number)
Sub Net mask: 255.255.255.0
Default Gateway: 192.168.1.1 (your server I.D.)
If Not:
Click on Wireless Information tab, wait for your wireless name to come up.
Click on your network name.
Click on Connect.
If the connection needs a network key(password) it will switch to Wireless Network Properties.
Uncheck "This key is provided automatically."
This will allow you to position your cursor in the Network key box and type your Network key.(password)
Click on OK.
You should see your red X down in the right corner disappear.
You are now ready to sign on to the Internet by typing your choice URL in the Internet Browser.
Note: that all internet locations are not available to CE 6 as this will only sign on to internet sites that can funnel you to the smart phone abbreviated sites. Not all sites have the ability to do this and your machine does not have enough memory to render the "Big" sites sign on window.
If you use the included "You Tube" apps icon, then this directs you to the abbreviated YouTube site. If you try to sign on to the "Big" YouTube site, it will give you a browser error
Stay tuned for other TIPS.
Computers & Internet Logo
cannot start engine after running out of fuel \fitted fuel filter and filled with diesel
I presume it is a diesel, as most diesel they usually need to be primed, refer to owners/service manual or your local dealer should be able to assist, more than likely an air block!!!
Feb 14, 2011 | 2003 Ford Focus
i went to plz block my face book id
You cannot block your account in Facebook, but you can change it to any invented name/email.Log in to facebook and at the top right, click on Account. Then click on settings, you can change your email, name and address-fill the gaps with invented name, email...an so on. This way your personal information will be deleted from facebook.
Feb 03, 2011 | Facebook Social Network
how to refill the radiator? as owners manual says read service manual as damage to engine can occur 4.7l V8
the only damage that could occur is if you were to fill a hot engine with cold water(warped block,warped heads)SO DONT FILL IT WITH COLD WATER WHEN HOT......
Sep 22, 2010 | 1999 Jeep Cherokee
hi,i just bought this 04 v-star 650 ,where does the engine oil go and where is the full mark i see a black fill hole in the engine block ,but there is no fill stick or mark how do you know when it is full,and does the clutch use the same oil or have its own fill hole,gary
Your best bet to address these questions and others you are going to have in the future, is to stop by your local Yamaha dealer and if you do not have one purchase the owners manual for your bike. It won't cost much and it will provide you with lots of information about your bike and scheduled maintance. Hope this helps.
JP
Nov 10, 2009 | 2001 Yamaha V Star 1100 Classic
2,955 people viewed this tip
David Payne
David Payne
