Tip & How-To about Computers & Internet
USB Flash Drive | Write Protected
Hello and Welcome to FixYa!
I have noticed similar queries that My USB flash drive is not formatting and showing the error that "The drive is Write protected" or something similar, although there is no protection latch or switch, So what to do.
There may be two issue one with the fat structure of the drive other with the components, if the hardware is damaged then there is no luck, but if the fat is damaged and windows is unable to format it, you can repair it with a nice and small tool.
Just download, extract and run this application to Repair your USB Flash drive.
Have resolved the Write protection issue on many drives with this, do share your experience as well.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
Computers & Internet Logo
memory card is wrtie protected how to remove it
I've answered a similar query here.
Hope that will be helpful.
Concerned, Nooh: Team FixYa!
Jul 09, 2011 | Sony Memory Stick PRO Duo (2GB) for PSP
i have transcend JF V30/4GB pen drive. Recently i am getting in the pen drive that i cannot do any format in the pen drive nor i cannot copy/delete the files in the pen drive. it was showing that "Windows was unable to complete the format" and "showing access is denied make sure the disk is not full or write protected and that the file is not currently in use." When i use the same pen drive in another system it is working normally. my laptop is ACER 4720 travelmate and recently installed WIN Xp. pls suggest
Kindly try this solution:
  • Connect the USB stick to another computer and copy all the data.
  • Download this file (click here) to that PC and format the USB stick using this program.
  • Now try to connect the USB stick to your ACER laptop and see if it works.
If you have any further queries, please do not hesitate to comment again. If this solution was helpful to you, kindly rate it.
Regards, Waqar.
May 22, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Disk is not formatted transcend jf v10 16g
Before you can use a USB stick it needs to be formatted with a proper file system (such as NTFS, ex-FAT or FAT32). The error message you are getting suggests that the USB stick needs to be formatted. To format it simply plug it in a USB port on your computer and open up My Computer (or Computer in newer version of windows). Right click on the USB drive and select format. Click ok and you are done. If you are having trouble with the built-in format tool, you can use this third-party format tool (click here). If you have any further queries, please do not hesitate to comment again. If this solution was helpful to you, kindly rate it.
Regards, Waqar.
May 21, 2011 | Garden
2 GB PENDRIVE SHOWING UNABLE TO FORMAT. AND ASLO
You can try to format the mp3 player.
Go through: Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
Try to format it with fat files system.
hope this help you
Regards
uttam
Jan 07, 2010 | Transcend (589307) Media
unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
May 22, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
254 people viewed this tip
David Payne
David Payne
