Tip & How-To about Lite On LH-20A1H DVD RW Dual Layer Burner
How to open the drive in case of emergency
Locate the pin hole in the drive
picture from gateway web site
Insert a straightened paper clip in this hole and push
the drive will pop open, now pull the tray out ..
NB different drives has this emergency release in different locations to the front of the drive
Lite On LH-20A1H DVD RW Dual Layer Burner Logo
CD DRIVE DOOR BUTTON JAMMED ON AX5900
You should see a small 'pin hole' on the face of the CD drive, usually near the eject button itself, but not always. Straighten a paper clip (med size is best) and insert into the hole. You will feel a little resistance (this is good) continue pushing the paper clip straight in until the door pops open. Almost all CD/DVD drives have this "manual open" pin hole for just such cases. Alternately you can open My Computer, point to the CD/DVD icon, right click and choose the "eject" option, this will open the tray if the physical button has stopped working.
Jul 15, 2014 | Acer Computers & Internet
Drawer won't open
There is a mechanical way of opening it. Straighten out a paper clip, find a very small hole on the face plate of the drawer slide. Insert the straighten paper clip end into the hole and push gently. this will push the unlatch triger and release the tray.
Jan 07, 2011 | Dell Inspiron 6000 8x DVD/CDRW Combo Drive...
Please explain how to open a cd drive in dell laptop using paper clip
First straighten a paper clip, then locate the pin hole which is located below the CD drive tray. Insert the straighten paper clip into this pin hole and push it in until the tray releases and pops out. You can then grab hold of the tray and pull it fully out to get at the disk in the tray.
Jun 23, 2010 | Computers & Internet
Will not eject DVD is working is stuck I think I might need to open laptop
Power down the laptop and restart it. As soon as it restarts press the open button on the dvd drive and it will open. You may have to try a few times but it will work.
Sep 29, 2009 | Dell Studio 1737 Laptop
I got a cd stuck in the cd/dvd drive for my gateway laptop- i dont know the model. tried to hit eject button and ejecting through computor and it will not open. what do i do?
All CDs & DVDs have a tiny hole on the drive tray.
Get a paper clip, straighten the paper clip and insert it into this hole and push the paper clip in gently, the tray will release and pop out, then you can remove your disc.
You can do this without the laptop being powered up or powered down.
Feb 21, 2009 | Gateway M305CRV Notebook
1,434 people viewed this tip
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Gbenga
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
