Tip & How-To about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Seagate External Drive Errors
It is always a good idea first to check the Disk Management before the Device Manager.
  1. Right-click on My Computer.
  2. Click on Manage.
  3. Choose Disk Management from the left column.
  4. Try to find the external drive in the lower window. It should be "Disk 1" or some other number (but not Disk 0).
  5. If it is displayed there, you can troubleshoot it inside the Disk Management (for XP/2000) (for Vista)(for Windows 7). If not, continue on.
  6. Then choose Device Manager from the left column.
  7. Choose Disk drives.
  8. If the drive is not seen there, check under Universal Serial Bus Controllers (if the drive is connected via USB). The drive should appear as a USB Mass Storage Device.
  9. If a yellow ! icon is displayed next to it, double-click on the drive.
  10. A Properties window will appear and will probably say "This device is not working properly" and will give either (Code 28) or (Code 10).
  11. If Code 10 appears, the drive has most probably failed. Verify by trying the drive with another USB cable or port, or on another computer.
    If the drive does not work on the 2nd computer, the drive is probably defective. You can begin a replacement request at our Warranty Services Page.
  12. If Code 28 appears, you will need to test the drive on another computer.
  13. If the drive functions correctly on another computer, the Windows USB drivers are corrupted or missing. You will need to try to reload the USB drivers for the operating system by inserting your Windows install CD, rebooting, and attempting a Repair/Restore.
    This can be dangerous to your data and you should disconnect your external drive before attempting this.
    If the drive does not function correctly on the 2nd computer, it is probably defective. You can begin a warranty replacement at our Warranty Services Page.
    For Vista and Windows 7 Only: If the drive works fine on another computer, there are a few steps to follow while the drive is connected to the original computer:
    1. Right-click on Computer and choose Manage.
    2. Double-click on the Device Manager.
    3. The device will usually appear under "Other Devices" or "Unknown Devices"; right-click on it and choose Uninstall.
    4. Once it has disappeared from the Device Manager, disconnect the device.
    5. Open a Windows Explorer window (right-click on Start > Explore).
    6. In the address bar, type c:windowsinf and press Enter. For Windows 7 type c:windowssystem32driverstore and press Enter.
    7. Delete the file INFCACHE.1.
    8. If you get an error when trying to delete this file, try the following steps:
      1. Right-click on INFCACHE.1.
      2. Select Properties.
      3. Click on the Security tab.
      4. Click Edit to edit permissions.
      5. Click Add to add Group or User name.
      6. Click on the user name under which you are currently logged in.
      7. Click on the Full Control box in the lower permissions section, then click OK.
      8. Delete the file.
      9. Reboot and reconnect the drive. The file should be rebuilt, correcting the problem.
      10. If that fails, you will need to try to reload the USB drivers for the operating system by inserting your Vista install CD, rebooting, and attempting a Repair/Restore.
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
PCI Slot 5 (PCI bus 1, device 7, function 0) IN DEVICE MANAGER THERE IS A YELLOW QUESTION MARK NEXT TO PCI MODEM.EVERYTHING SEEM TO BE WORKING NORMALLY BUT WHEN I START MY COMPUTER I AM BEING INFORMED THAT SOMETHING IS MISSING AND WHEN I TRIED TO INSTALL EXTERNAL HARD DISK IT SAID INSTALLER ERROR,WINDOWS COULD NOT LOAD THE INSTALLER FOR VOLUME,I CLICK OK AND IT SAYS HARDWARE IS INSTALLED AND I CAN SEE IT ON THE TOOLBAR BUT UNDER MY COMPUTER I CAN'T.USB STICK WORKS NORMALLY AND I CAN SEE IT ON MY COMPUTER
If you don't need the modem, you can safely disable this questionmarked device in Device Manager, so it does not nag you every time you start Windows.
As far as the disk is concerned, you may try going to Disk Management (in XP you right click My Computer and choose Manage, a Computer Management window will show Disk Manager will be on the list near the end).
Study the list of volumes listed in Disk Manager; if you see a volume of more-or-less the same capacity as your ext. disk, and without a drive letter assigned, than right-click that volume and choose Assign / Change Drive Letter. Choose a letter farther into the alphabet so it doesn't interfere with any existing volumes - my favorite is X: for eXternal :) - and confirm.
After that operation the drive should appear in My Computer.
Jul 24, 2011 | Computers & Internet
My lacie harddisk doesn't show up in windows XP. Power is ok. Light is on and he makes normal operating noise like always. I have another one for which I use the same USB-chord and that one is working perfect. Thanks.
1. right click the my computer
2. go to properties
3. click hardware tab
4. and click Device Manager
5. show the Device Manager and click disk drives
6. your hard disk is show or not.
7. it's show then go my computer properties
8. select manage and show computer management window
9. then click disk management
10. your hard disk partitionis show right click the partition add driver letter (ex: h:, i: ..)
11. after open the my computer the partition is show
thankyou
Sep 15, 2010 | LaCie F.A. Porsche (301177) Hard Drive
How do i get a new hard drive to recocgnize the external drive
Connect the external storage
Click Start
Right-mouse click My Computer
Click Manage
Click Storage
Click Disk Management
Check to see if there is a "healthy" partition covering the disk-space of the external storage device.
Jun 24, 2010 | NexxTech Portable Hi-Speed USB 2.0 Kit...
cant open or format 4gb kingston flash
Right click on My Computer, choose Manage
A Computer Management console will appear.
On the left lokk for Disk Management and click on it.
Wait a little until the values on the right loads.
Now locate the Kingston drive, right click it and format it.
Don;t forget to rate this answer if it helps
Jul 20, 2009 | Electronics - Others
not registering on my computer
Open Disk management (Right click "My computer" choose "Manage" and select Disk Management). Can you see the drive there?
If there's nothing saved on the HDD >> right click the drive in Disk Management, choose "New partition" and follow the wizard to format the drive.
Apr 10, 2009 | Fantom G-Force MegaDisk 1.0TB 7200RPM USB...
2,063 people viewed this tip
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
