Tip & How-To about Pioneer DVJX1 Turntable
DVJ-X1 Cue before inserting disk.
The DVJ-X1 has a fun little bug/feature that is often over looked.
For a cd press the track forward/previous to select the track you want to play BEFORE you insert a disk, once you have the disk inserted and it initializes the deck will cue to that track automatically.
With a DVD you need to also select the TITLE as well as the TRACK most of the time with promo only or rock america disks there is only one track for videos so select TITLE 01 first then the appropriate Chapter.
Pioneer DVJX1 Turntable Logo
I can only get my mp3 player to play the song for 10 sec???????
Your player is in "intro" that means all the tracks will be played for 10 sec only. This feature can be swithed off:
On the main menu, select the "Settings" item and press the MENU button
to enter the system settings mode.
Press the PREVIOUS/NEXT button to select setting item and press the
MENU button to confirm or press the PLAY/PAUSE button to
cancel/return.
You should find Music then Repeat mode, here you can select another mode then "Intro" for example Once, Repeat Once, Folder...
I hope I could help.
Thanks.
gylacz
May 15, 2011 | Sylvania SMPK2072 MP3 Player
I have a RCA RT 2770 receiver and the usb port does not detect any devices. It does have power as I have connected an IPod and it charges via the usb port. It just does not detect the mp3 player, IPod or external hard drive.
look here
http://www.voxxsupport.com/images/manuals/RT2770/media/RT2770_UMEN.pdf
USB Device Playback Features
(Only support MP3/WMA file)
1. Press USB on front panel or remote control
to select USB mode.
2. Press to start playback or press to
pause playback.
3. Press to end playback.
4. Press CH+/- on the remote control or /
on the front panel to skip to the previous or
next file.
5. Press REPEAT on the remote control to select
repeat mode. (REPEAT ONE, REPEAT FOLDER,
REPEAT ALL, REPEAT OFF)
6. Press RANDOM on the remote control to
select random play mode. (RANDOM ON,
RANDOM OFF)
7. Press INTRO on the remote control to turn
on/off intro mode. The unit will play the first
ten seconds of each track on the USB device.
8. Press DISPLAY on the remote control to
select among mp3/WMA ID3 information,
elapsed time,current play Folder and Track
number and Play Mode.
Dec 10, 2009 | Audio Players & Recorders
Player stops mid track and shows ''no disc''.
HELLO
Have you tried cleaning the lens? It's incredible how a dirty lens can cause so much grief! You'll need the CD player cover removed and powered off then get some isopropyl alcohol and a cotton bud. Wet the bud but not too much get any excess moisture off.
Using a careful circular motion clean the lens, let it dry and try the player again. If this does not cure the problem, you may have a defective laser and that will need replacing.
ALL THE BEST (:-)
Oct 04, 2009 | Audio Players & Recorders
Cd does not play when inserted. We cleaned the lens with a lens cleaner.
The optical lens assembly is damaged at this point. the lens has burned out and the tracking/load motor seems to be faulty as well. replace the optical lens asap.
Jun 02, 2009 | Sony Audio Players & Recorders
CLOCK
You can download the manual from the link below: http://safemanuals.com/user_guide_instructions_owner_manual_CLARION_DB165_E.htm Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 11, 2007 | Clarion (DB165) CD Player
969 people viewed this tip
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
