Tip & How-To about Microsoft Internet Explorer 8
How to increase your internet by 20% ?
If you use Windows XP Professional then it is possible to squeeze an extra 20% out of your internet connection. By default Windows XP Pro holds back 20% of your Internet speed for various services like windows update and spyware checks.
If you want to tap into this locked speed then make the following changes:
• Go to Start-> Run-> and type gpedit.msc
• Expand the Administrative Templates branch
• Expand the Network tab
• Highlight QoS Packet Scheduler
• Click on Limit Reservable Bandwidth and check the 'enabled' box
• Then Change the Bandwidth limit % to 0 %
Once you've done this click apply and restart your PC. After rebooting you should see a noticeable improvement in your net speed.
Microsoft Internet Explorer 8 Logo
how to adjust or can increase internet speed
If you are using Windows XP Professional then it is possible to squeeze an extra 20% out of your internet connection. By default Windows XP Pro holds back 20% of your Internet speed for various services like windows update and spyware checks.
If you want to tap into this locked speed then make the following changes: • Go to Start-> Run-> and type gpedit.msc • Expand the Administrative Templates branch • Expand the Network tab • Highlight QoS Packet Scheduler • Click on Limit Reservable Bandwidth and check the 'enabled' box • Then Change the Bandwidth limit % to 0 % Once you've done this click apply and restart your PC. After rebooting you will amaze a noticeable improvement in your net speed. goodluck....
Feb 22, 2011 | Computers & Internet
video buffering
videos like youtube buffer depends on the net speed you are receiving if your isp provides only low speed then it's normal that your videos always buffer and take time to load;;there's a trick to increase your net speed..try this one:
Goodluck!!don't forget to rate!
Feb 21, 2011 | YouTube Videos
how to make youtube videos faster
If you use Windows XP Professional then it is possible to squeeze an extra 20% out of your internet connection. By default Windows XP Pro holds back 20% of your Internet speed for various services like windows update and spyware checks. If you want to tap into this locked speed then make the following changes: • Go to Start-> Run-> and type gpedit.msc • Expand the Administrative Templates branch • Expand the Network tab • Highlight QoS Packet Scheduler • Click on Limit Reservable Bandwidth and check the 'enabled' box • Then Change the Bandwidth limit % to 0 % Once you've done this click apply and restart your PC. After rebooting you should see a noticeable improvement in your net speed.
goodluck!!!
Feb 21, 2011 | Computers & Internet
1,113 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
