Tip & How-To about Plumbing
How to replace garbage disposal
Take advantage of fixya expert assistance live.
For a price, fixya expert works with you while you work on disposal or any do-it-yourself project.
Fixya is always less expensive than a service call.
Plumbing Logo
water runs out the bottom of badger 5
Once water is running out of bottom, then disposal is rusted out and needs replacement.
If the leak is plugged, then water fills up the motor and shorts out.
I wrote ez disposal replacement steps:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Sep 02, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
MY GARBAGE DISPOSAL IS WORKING BUT THE WATER IS NOT DRAINING. I TRIED THE ALLEN WRENCH BUT DONT HAVE THE CORRECT SIZE. CAN YOU TELL ME WHAT SIZE TO PURCHASE PLEASE
Use a broomstick handle down inside the disposal to wedge the cutter disk free.
Broomstick works just like allen wrench.
If cutter disk rotates, then clean out the tubular pipe that connects to disposal.
Remove trap under sink, and then remove tailpiece connected to side of disposal.
Clean out disposal.
I wrote tips for working on tubular drain pipes that might help.
Upvote the help.
For a price, expert works with you while you work on disposal or any do-it-yourself project.
May 28, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
my garbage disposal stopped working sometimes it sounds like it wants to start for just a second but it never does. should I buy a new one?
If disposal is getting power and will not start, then motor has gone bad.
I wrote ez disposal replacement steps from when I worked apartment maintenance
Upvote the help.
May 27, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My Badger 5 disposal leaks from a 3/8 inch vertical casing split just above the discharge line. Is this repairable?
Disposal leaks are not repairable.
Once the metal rusts out, you replace it.
I wrote ez disposal installation tips from years when I worked apartment maintenance:
Upvote the help.
For a price, expert works with you while you work on plumbing or any do-it-yourself project.
May 18, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
dishrag caught un disposal, pulled it out, blades turn, it just hums, it hums even when switch is turned on off!!
If cutter disk turns freely and motor hums, then motor winding has gone bad.
The humming sound means motor is overheating and will stop humming.
I wrote ez garbage disposal replacement steps from days when I worked apartment maintenance.
Upvote the help.
May 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
6,541 people viewed this tip
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
