Tip & How-To about Computers & Internet
How to Troubleshoot a Mac Computer With No Sound
When troubleshooting sound problems on Macs, you can find thefix quickly if you isolate the possible problems first. Regardless of youroperating system, it will make things easier if you can narrow down thepossible points of failure by momentarily unplugging any sound devices.Following simple change of sound settings and testing internal sound alerts canfix the problem.Instructions
1. GeneralTroubleshooting
    • 1
Launch iTunes or another media player applicationand have it play continuously to start troubleshooting. Make sure the volume isnot muted or disabled. Move the volume slider on the menu bar up and down. Youcan also use the keyboard's Increase and Decrease volume buttons (usually F4 todecrease and F5 to increase the volume).
    • 2
Unplug any headphones that might be connected toyour computer's headphones port. If your computer has internal speakers,unplug any external speaker plugged to the audio port to isolate the problem.Check if sound is working properly through the internal speakers.
    • 3
Go to System Preferences on your Mac menu. Clickon the ''Sound'' icon, under the Hardware section. The Sound settings pagedisplays three main buttons: ''Sound Effects," ''Output" and''Input." Click on the ''Output'' tab. Select the ''Internal Speakers,Built-in Output'' option, and raise the ''Output Volume'' at the bottom of thatwindow. Check if sound is working properly.
    • 4
Go to the ''Sound Effects'' tab, and make sure the''Alert'' and ''Output'' volumes are up and not muted. Select ''InternalSpeakers'' from the ''Play alerts and sound effects through'' drop-down menu.Click on any of the Alert Sounds in the left column and test to see if theysound as you change from one to the other. Check if sound is working properly.2. GaragebandTroubleshooting
    • 1
Launch GarageBand. A default piano track willappear. If it doesn't appear, click on the ''Track'' Menu and select ''NewTrack''. Choose a Software Instrument from the dialog box, and then choose aPiano from the selection of Instruments.
    • 2
Click on "Menu." Select ''Preferences''and click on the Audio/MIDI tab. For Audio Output, and Input select thecorresponding ''Built-In Output'' and ''Built-In Input'' from the drop-downmenus. Confirm the action.
    • 3
Click on the Piano track. Under the ''Windows''menu bar, select the ''Keyboard'' option, or press [ Command + K ]. A keyboarddisplays. Click on any of the keyboard keys. You should hear sound coming outof your internal speakers.
Make sure there is no headphone jack inserted in the computer. If sound doesnot work, try quitting the application and launching it again.
    • 4
If any of the previous steps do not fix the soundproblem, reboot and try again.
If you see a Disabled Volume alert when you try to raise the volume, alsoreboot. This is a known bug in Macs
Computers & Internet Logo
format seagate central drive
Lots of info here
  • Seagate Central ' Seagate www.seagate.com/.../network-storage/seagate-central Seagate Central Drive - Quick Start Guide, Installation, Troubleshooting Tips & Downloads.
  • Reformat Seagate Central NAS - NAS / RAID - Storage www.tomshardware.com > Forum > Storage HI - anyone know if it is possible to reformat the Seagate Central Home NAS boxes with NTFS. Also anyone know ifit is possible to use Active Directory user accounts?
  • Seagate Technology - Official Site www.seagate.com Seagate is the company the world trusts to store our lives - our files and photos, our libraries and histories, our science and progress.
  • How to format your hard drive - Search ' Seagate knowledge.seagate.com/articles/en_US/faq/220151en How to format your hard drive Seagate external drives come preformatted, some for PCs, some for Macs, and some of them have special utilities allowing them to work ...
  • VIDEOS TOO
  • Go to Bing homepage
    Aug 03, 2016 | Seagate Technology Seagate Central 2TB
    My 2002 mitsubishi montero sport is making a creaking sound from the left front side torsion bar. Helpp!
    Would look first at condition of bushings. Live in a dry area? Rubber bushings dry rot quickly in Colorado, New Mexico, etc. If you have already isolated it that well, though, then you probably already checked that, so apologies if this tells you nothing new, but there are not that many possibilities for creaking sounds from front suspension. Ball joints usually clunk or pop, and strut/spring mounts seem out of range based on your description.
    Jul 20, 2014 | Cars & Trucks
    Wiring a trailer light harness.
    Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
    Troubleshooting 4 and 5 Way Wiring Installations
    Trailer Wiring Diagrams
    Yamaha FJR1300R Service Manual
    OEM parts for Yamaha
    Yamaha FJR1300R Owner Manual
    May 17, 2012 | 2006 Yamaha FJR 1300 A
    QSC 2450 Power amplifier
    i have a pyle pro 1000 watt max 2 channel mono and 2 channel stereo and when i get that thing loud the little red light cums on basically what i mean is that the amp on channel one is cooked i myself i wouldn't even use it y cause more damage
    Apr 03, 2008 | QSC RMX-2450 Car Audio Amplifier
    HP Pavillion Entertainment PC
    hmmm i think you all should buy macs. pcs ****
    Feb 27, 2008 | Microsoft HP Pavilion DV6276US Notebook PC
    311 people viewed this tip
    David Payne
    David Payne
