Tip & How-To about Computers & Internet
File Sharing in Windows 2000/XP Pro
Before setting up file sharing
  • Your computer must be connected to the campus network in order to set up file sharing. If you need to connect your computer to the network.
  • You will need to log into your computer using an Administrator account (in most cases, this is the account you normally log in with).
  • Make sure you are logging into your computer by using a password and that every other user account on your computer is set up with a password. If your computer does not have password-protected user account(s), you are at high risk from hackers taking over your computer and using it for illegal purposes without your knowledge.
  • Install the latest security patches and updates.
  • Check your anti-virus program and make sure it is up-to-date.
  • For computers with Windows XP Pro:
    • If your computer was set up to work on a LAN at home or any place other than Wellesley, you must disable the non-Wellesley network connections in order for file sharing to work correctly. Note: You will need to re-enable these connection(s) when you take your computer off the Wellesley College network, i.e. off-campus.
      1. Go to the Start menu and select the Control Panel.
      2. If you do not see the Network Connections icon in the Control Panel, click on the link for Switch to Classic View near the top left of the window.
      3. Double-click on the Network Connections icon.
      4. In the Network Connections window, to check which Local Area Connection icon is for Wellesley, select the icon and make sure the Details menu on the left side of the window is displayed (double-arrows next to the word Details should be pointing down). The IP Address should start with 149.130.
      5. If you see any other Local Area Connection icons or 1394 Connection icons listed in the Network Connections window, right-click on the connection and select Disable from the menu.
      6. Close any open windows.
    • If you have Windows XP Pro's Internet Connection Firewall enabled, it will prevent your computer from being able to share files and prevent you from using several resources at Wellesley College. To turn it off:
      4. In the Network Connections window, right-click on Local Area Connection (the one for Wellesley as described in step 4 above) and select Properties from the window.
      5. Click on the Advanced tab.
      6. Uncheck Protect my computer and network by limiting or preventing access to this computer from the Internet and then click OK.
I. Configure your computer for file sharing You will only need to configure your computer for file sharing once. If the option for file sharing is already set up on your computer or if you wish to set up another shared folder on your computer.
    1. Go to the Control Panel.
      • In Windows 2000, click on the Start button and then select Settings > Control Panel.
      • In Windows XP Pro, click on Start and then select the Control Panel.
    2. Double-click on the Network Dial-Up Connections or the Network Connections icon. In Windows XP, if you do not see this icon, click on Switch to Classic View located on the left side of the window to see all Control Panel options.
    3. In the new window that appears, right-click on the Local Area Connection icon and select Properties from the menu.
    4. In the Local Area Connection Properties window, check that the General tab is selected. Under the This connection uses the following items: or the Components checked are used by this connection section, check that File and Printer Sharing for Microsoft Networks is listed and make sure that its checkbox is checked. If it is listed, the computer is already configured for file sharing; click Cancel and skip to the next section.
    5. Click the Install button.
    6. Click once on Service to select that option.
    7. Click Add.
    8. Click once on File and Printer Sharing for Microsoft Networks to select it and then click OK.
    9. Click Close.
    10. If the computer asks to restart, click No.
Setting up the folder that will be shared Only folders may be shared, not individual files, i.e. if you wish to share a file named blue.doc, then you must put blue.doc inside a folder and then share that folder by following the directions below. Note: If a Windows 98 computer is going to access your shared folder, then the name of your shared folder should not contain any spaces.
    1. Right-click on the file or folder to be shared. In the drop-down menu that appears, select Sharing or Sharing and Security.
    2. Select Share this folder. The name of the folder that appears on the network may be changed by typing in the new name in the Share name field.
    3. Click on Permissions.
    4. Click once on Everyone to select it and then click Remove.
    5. Click Add.
Computers & Internet Logo
i can not get my kodak hero 5.1 printer to work on my windows xp 64 bit
Turning sharing on or off
The first time you connect to a network, you'll be asked if you want to turn on sharing between PCs and connect to network devices such as printers. Your answer automatically sets the appropriate firewall and security settings for the type of network that you connected to. You can turn sharing on or off at any time.
To turn sharing on or off
  1. hh_ppeic.pngTap or click to view available networks.
  2. Press and hold or right-click the network you're connected to, then tap or click Turn sharing on or off.
    435600ef-5a98-4568-bfa2-28d51981b1e3_13.jpgMenu used to turn sharing on or off
  3. Do one of the following:
    • Choose Yes, turn on sharing and connect to devices for home or small office networks, or when you know and trust the people and devices on the network. This setting allows your PC to connect to devices on the network, such as printers.
    • Choose No, don't turn on sharing or connect to devices for networks in public places (such as coffee shops or airports), or when you don't know or trust the people and devices on the network.
      Notes
      • Turning sharing on prepares your PC for sharing files and devices on a network. For more information about sharing with other people on your network, see Sharing files and folders on a network or a shared PC.
      • The network sharing setting is only available for WiFi, Ethernet, VPN (non-domain) and dial-up (non-domain) connections. It's unavailable for domain networks. On VPN or dial-up connections, you must connect to the network first, then press and hold or right-click the network name to change the network sharing setting.
      • Turning on sharing changes your firewall settings to allow some communication, which can be a security risk. If you know you won't need to share files or printers, the safest choice is No, don't share or connect to devices.
      • Choosing No, don't turn on sharing or connect to devices blocks the following applications and services from working: PlayTo, file sharing, network discovery and automatic setup of network devices.
About network discovery
Network discovery is a setting that affects whether your computer can see (find) other computers and devices on the network and whether other computers on the network can see your computer. It's one of several settings that are turned on when you turn on network sharing. You can turn network discovery on or off independently of network sharing, but we discourage this. Here's why. If you're connected to a network in a public location and you decide to turn on network discovery but leave network sharing turned off, the network discovery setting will be on for every public network you connect to from then on. This wouldn't be safe. That's why we recommend using the network sharing setting instead.
However, if for some reason you need to turn network discovery on or off independently of the network sharing setting, here's how to do it:
  1. hh_ppeic.pngTap or click to open Advanced sharing settings.
  2. Tap or click the chevron 7d2e0f87-bcfb-44a3-8422-5c9353bcde11_89.jpg to expand your current network profile.
  3. Tap or click Turn on network discovery or Turn off network discovery, then click Save changes. 1f9463c2-c968-47bf-9b4d-939c5d1af477_70.jpg You might be asked for an admin password or to confirm your choice.
Jan 07, 2012 | Kodak Office Equipment & Supplies
i want to network two pc with windows xp using crossover cable,, how do i do it step by step pls.
Connect two computers using a crossover cable
If you need to connect two computers but you don't have access to a network and can't set up an ad hoc network, you can use an Ethernet crossover cable to create a direct cable connection.
Generally speaking, a crossover cable is constructed by reversing ("crossing over") the order of the wires inside so that it can connect two computers directly. A crossover cable looks almost exactly like a regular Ethernet cable (a "straight-through" cable), so make sure you have a crossover cable before following these steps.
Before buying a crossover cable, check your network adapter. Some newer network adapters automatically "cross over" when they detect that they are connected directly to another network adapter using a regular Ethernet cable.
To connect two computers with a crossover cable
This works best if both computers are running this version of Windows.
Plug each end of the crossover cable into a network port on the back of each computer.
On one of the computers that is running this version of Windows, do the following:
Open Network and Sharing Center by clicking the Start button , clicking Control Panel, clicking Network and Internet, and then clicking Network and Sharing Center.
In the network map at the top of Network and Sharing Center, double-click the Unidentified network? icon. (If you have more than one network, this icon will be labeled Multiple networks.)
If network discovery and file sharing are turned off, in Network, click the Information bar containing the following message: "Network discovery and file sharing are turned off. Network computers and devices are not visible. Click to change...," and then click Turn on network discovery and file sharing. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
In the Network discovery and file sharing dialog box, select one of the following options:
No, make the network that I am connected to a private network
Yes, turn on network discovery and file sharing for all public networks
The first option is usually the best choice because it only affects the network that you are connected to.
Notes
Networks created with crossover cables are automatically set up as "Public place" networks, which means that network discovery, file sharing, and printer sharing are off by default.
For Gigabit Ethernet or token ring networks, you will need a slightly different kind of crossover cable. For more information, contact a cable manufacturer.
Icons for both computers should now be visible in the Network window. Double-click each computer icon to share printers and other resources.
Note
If one of the computers is running Windows XP, it can take some time for that computer to appear in the Network window. You might need to move both computers to the same workgroup. You can do that by changing the workgroup on either computer. To change a workgroup, see Join or create a workgroup. You might also need to turn on file and printer sharing on the computer running Windows XP.
Hope this help!
Sep 06, 2011 | Pine Technology Motherboard Xfx Nforce...
I would like to share files between two computers
There are several things you need in order to share files between two computers on a network:
1. You should both be in the same "workgroup" , in Win 7 it's called "homegroup"
2. You also need to have "file and printer sharing" enabled under your network connection properties
3. AND you also need to set the drives/folders or files you wish to share to "sharing" /"share as" in order to give permission to access
Note that with Windows 7 files that are to be shared can only be easily accessed under USER, PUBLIC folder. On older OS you can set most any drive and folder to a SHARE
To instruct you how to do these things I need to know what operating systems you have on the machines you wish to share files on.
Feb 05, 2011 | Computers & Internet
i can not connect to the internet. i keep get error message 80028E02.
ps3 error 80028e02 can be caused by different source of network blockages. If you happened to be in a filtered network, that's your most probable reason why your ps3 is unable to connect online. For example, if you're in a school campus, there's a high chance that the IT network administrator has placed some restrictions to prevent hackers and other malicious online activities. You can refer to the campus IT department to find out if you need to access their local page for some clearance in order for your ps3 to connect online.
If you have your own internet connection, the next probable cause is a router. Placing restrictions on some IP address or net services may have accidentally include your ps3 in it. You can change some settings within the router to grant your ps3 full access online, while at the same time maintaining other restrictions that are already in place.
Another possible remedy is have your pc internet connection shared, and use your ps3 to use that shared connection to go online. These solutions are sure fire methods of keeping ps3 80028e02 away from your console.
reference: http://www.dtheatre.com/read.php?sid=5603
Dec 16, 2010 | Sony Playstation 3 (PS3) Console
I have a Brother HL2070N printer. I have 2 computers and want to share the printer. I connected the printer via the USB port to Computer 1 and it prints fine. I set the printer to SHARED. Computer 1 has a direct connection to the internet via a wireless router. Computer 2 shares the internet connection via a wireless card. I cannot print from Computer 2. When I try to Add Printer on Computer 2 it does not see the shared printer.
hi there,
Because printers and networks vary, the best instructions for setting up and networking your printer should be in its users manual. Also, your network-ready printer may have come with installation software that can help you share the printer over the network.
There are three main steps you need to take when networking a printer, including the following: Enable the File And Printer Sharing setting, Make the printer available to all users, and Direct PCs to the printer.
For detailed instructions on sharing printers at home, please refer to the "Get Your House In Order" article in the "See Also:" section below.
For detailed instructions on sharing printers in a small business, please refer to the "Select & Share The Right Printer For Your Small Business"
Apr 14, 2009 | Brother Office Equipment & Supplies
749 people viewed this tip
David Payne
David Payne
