Tip & How-To about Computers & Internet
Removing password from Windows XP/2000/ME
Many people want to know how to remove the local password for a computer running Windows XP/2000 or ME. This is as simple as a download.
The program Offline NT Password and Registry Editor http://www.pogostick.net/~pnh/ntpasswd/ is an easy to use bootable program that can remove a password in under a minute.
Once you create the disk from the link above you can reboot your system and load it. Then follow the onscreen prompts as to which installation of windows and what user to reset. Once you reset the password tell the program to save back to disc. Remove the disc and reboot the system.
The creator of the program provides easy to use instructions here
Good luck
Computers & Internet Logo
forgotten pasword for dell dimension 3000
If you want the quickest way, then I think you can take a try this password recovery software, a program which helps to reset Windows Administrator login password easily. Fully compatible with Windows 7, Vista and XP etc operation system, supporting both 32-bit and 64-bit. Your DELL Dimemsion is supported. Good luck!
Jul 27, 2010 | Dell Dimension 3000 PC Desktop
how to unlock a dell windows XP home adition laptop when turning on laptop?
Do not worry, we can use dell password recovery tool to complete this task. Windows Password Rescuer is designed for resetting dell Windows 7/vista/XP password. What you should do is prepare a bootable CD/DVD or USB drive and a computer you have access to. Follow four steps help you reset dell windows password without lose anything:
Note: You also can use Windows Password Rescuer to reset Windows 2008/2003/2000 local or domain password easily by these steps on dell computer.
Step 1: Download and install Windows Password Rescuer on another computer you have access to.
Step 2: Run the software to create a Windows password recovery disk. You just need to burn it to a blank CD/DVD or USB drive.
Step 3: Insert the Windows password recovery disk to your dell laptop or dell computer, and set the computer boot from the password recovery disk by BIOS setting. If you have trouble in BIOS setting, refer to:
How to set computer boot from CD/DVD.
How to set computer boot from USB drive.
Step 4: After boot from the password recovery disk, Windows Password Rescuer will start up and display a friendly operating window. Then you can reset whichever account password of your dell computer just by a few clicks.
You also can use Windows Password Rescuer to create a new user with administrator privileges for your dell OEM Windows without login. With this new user, you can login your dell computer directly and access control panel to reset other user password.
Jul 11, 2010 | Dell Microsoft Windows XP Home Edition
Lost administrator password
as a person who works with computers, maintenance, I can tell you that no one should give you the answer how to go through that. It is highly illegal. Anyway, you can always try ERD commander. Ther is a program BLACKSMITH
Nov 14, 2009 | Fujitsu Siemens LifeBook E4010 Notebook
177 people viewed this tip
David Payne
David Payne
