Tip & How-To about Office Equipment & Supplies
Download and Install HP USB Printer Drivers in Windows 7
To get an HP printer running with your computer, you first need to install the software and drivers. Here are a couple videos I've created that explain how to install the USB drivers in Windows 7.
Choosing between a full and basic driver:Check out the video explaining the difference between the basic and full before jumping to the other videos. Often people download the basic driver because it's a smaller file and expect to be able to do the same things as the full driver. The basic driver is just that - a BASIC driver.
Downloading and installing a full driver (recommended):
Downloading and installing a basic driver:
Need a driver for gr-x5u video camera
http://support.jvc.com/consumer/product.jsp?modelId=MODL027421&pathId=26&page=1&archive=true
I think you're best option is to look for software that is compatible with your MiniDV camcorder. It seems Cyberlink was the original install software, so I would try finding or buying Cyberlink to see if it will work for your camcorder on a Win7 machine. If the link doesn't work, you might have to cut and paste twice.
Jan 18, 2012 | JVC GZ Video Cameras
Lost software to printer
You can download software from HP website, I will give you the link
Aug 26, 2008 | HP Officejet 5610 All-In-One InkJet...
can't install 1210 printer
Insert the software disc for the HP 1210 printer before you plug the printer into the computer with the USB cable. Allow the disc to install the software. You will be prompted to choose a destination for the software.
Plug in the printer USB cable to the computer when the installation program tells you to. This will be after it has installed any drivers that you need to run the printer on the computer.
Complete the installation by running a print test to make sure the printer software is installed correctly. You may remove the disc after the print test is complete. Installation without a Disc Visit the website http://welcome.hp.com/country/us/en/support.html to find the available drivers needed to run the printer on your computer. On this page, select "Download drivers and software." Enter "HP 1210 printer" in the product box and click the arrow to find the drivers. Select your printer from the list provided. This will take you to the next page, on which you will indicate your operating system. Select the "HP Officejet and PSC Full Feature Software and Driver" under "Driver" to begin the download. After the download is complete, you can open the file from the download location and install the software and drivers. Follow the installation software's prompts, after you finish download the drivers you need to double click it,it will give you the option to RUN or DON'T RUN the driver click on RUN and it would continue the installation. Run a test print.
Aug 27, 2010 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1410 All-In-One Ink Jet Printer cd installer
Go to www.hp.com/support, select your country, state, next page, select drivers and software and in the window just below it, type in hp psc 1410, it will give you choices, select your printer, run or save to a location on your hard drive. If you prefer to save, double click on it and it will create a directory on your hard drive. Open the directory and run the software. It might be adviceable to unplug your usb cable before running the software.
May 24, 2008 | HP PSC 1410 All-In-One InkJet Printer
322 people viewed this tip
k24674
jasbo
jasbo
