Tip & How-To about Welding Tools
Welding helmet lens covered with spatter?
Is your welding helmet glass dark lens covered with spatter from welding and need replacement often? Cut a piece of 1/16" (1.5mm) clear perspex to the same size as the lens and install this in front of the dark glass. Spatter does not adhere to the perspex and the glass lens will be protected indefinitly.
Welding Tools Logo
How do I change the battery in my welding hood cause sometimes the lens will darkin and sometimes it won't? Also the lens will not adjust the darkness when I change the shade
This Helmet is solar powered leave it on your dash to charge it a few hours will work just fine there is no battery the solar cell holds the power Try getting a full charge on it then see if the darkness will adjust .
Nov 23, 2010 | Uvex Optrel Satellite Welding Helmet #...
my lens is cracked on my flip cam, how do i fix it?
They aren't too hard to open up and take apart. There's a glass piece the covers the actual lens and I'm guessing that is what broke. Once the flip is in pieces you can remove the glass piece and it will operate fine without it. If you want to replace it, you can either get a broken flip and use it for parts, but there's a pretty sticky, tough ring of tape holding that glass piece in place. You could also try a very clear piece of plexiglass and cut it to size. Haven't tried that one myself, but it may work.
Apr 15, 2010 | Pure Digital Flip Video Ultra Camcorder
finger print marks on the screen
you mean clean the screen ??
any solution designed to work with perspex or acrylic will be perfect. try "uvex" products or those designed for perspex motorcycle crash helmet visors.
i had a few rear projection tvs over the years and normal everyday household polish didnt do mine any harm at all.
also a damp cloth will remove fingerprints but will leave smears. so skip the washing stage and just use an everday household polish without beeswax in it ,cos that puts a waxy coating on it. stay away from any alchohol based products.and if in doubt try the uvex stuff
http://www.envirosafetyproducts.com/product/Uvex-Clear-Lens-Cleaning-Solution-16-ounce-Pump.html available outside the us as well, made for cleaning safety glasses,
Feb 07, 2010 | JVC HD-61Z575 61" Rear Projection...
885 people viewed this tip
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
