Tip & How-To about Computers & Internet
How to solve acces denied issue while adding printer in windows server 2008
You might have faced access denied issue while trying to add printers in windows server 2008 using add printer wizard.see the pic below
To solve this, Right click on Add printer and select Run as Administrator option
Now you can install printer without any issues.You need to chose either local printer or network printer and continue
Computers & Internet Logo
Netgear ps121 won't print
Possible reason why you cannot print with the print server is because the computer is not getting a valid IP from the router or a firewall is installed in the computer. You have to disable all firewalls installed in the computer.
For the print server setup, please follow the steps below:
Note: Before setting up the print server, make sure that you can print when printer is connected directly to the computer.
1. Wire the print server to router. Check the lights on it. It should have the ACT light on and the Error light off.
2. One way to test if the printer would work with the print server is to reset the print server for 3 to 5 seconds while it is powered on and after you release the button, the printer should automatically print the IP address of the print server.
Note: If the printer did not print, there is a possibility that they are not compatible. However, you may still continue to try to set up the print server.
3. Install the PS121 software.
a. Power on your computer, let the operating system boot up completely, and log in as needed.
b. Insert the Resource CD for the PS121 into your CD-ROM drive. The CD main page shown at the right will load.
c. Click Install Software.
d. Click Next and follow the software installation utility prompts to complete the software installation.
e. When prompted, restart your computer to complete the installation.
f. When your computer restarts, click Finish to run the Print Server Setup Wizard.
4. Run the Print Server Setup Wizard to Set Up a Fixed IP Address for the PS121.
a. The Print Server Setup Wizard screen should be displayed.
b. Click Next to proceed. The Print Server Wizard will now search your network for the PS121. If the Print Server Setup Wizard cannot find your PS121, check the network connections and status lights on the PS121.
c. The “Server Name” and the “IP Address” your network assigned to the PS121 are displayed. Click Next to proceed to the device name screen.
d. You can enter a descriptive Device Name and Domain Name or accept the defaults. Click Next to proceed to the IP Address configuration screen. The Print Server Wizard displays a recommended static IP address setting for the PS121. This is usually fine.
e. Click Next to proceed.
f. Click Finish to exit the Print Server Setup Wizard. This completes the configuration of the PS121 for operation on your network.
g. Click Yes to run the Add Printer Port Wizard. Follow the instructions in the next section for using the this wizard to set up each computer to use the PS121.
To set up each computer to use the PS121, please follow the instructions below:
1. Use the NETGEAR Add Printer Wizard to set up each PC to use the PS121.
a. When the Print Server Setup Wizard finishes, you are prompted to run the Add Printer Port Wizard. Click Yes to proceed. Alternatively, from the Windows Start menu NETGEAR Print Server program group, you can run the NETGEAR Add Printer Wizard.
b. After a short delay while the software searches the network for your PS121, the Printer Select window opens and displays the PS121 you have set up.
c. Click Next to proceed to the Port/Printer name screen. Take note of the printer model number listed.
2. Set up the correct printer driver for the printer port.
a. Click Next to proceed to the Port/Printer name screen. Take note of the printer model number listed.
b. Click Next to proceed to the Select Printer screen. If you see the exact printer model number listed as the printer model number from in the previous screen, click it to select it from the list.
c. If prompted, print a test page to verify operation of the printer and the PS121. Then, close any remaining Add Printer Port Wizard or Windows Add Printer Wizard windows.
Use the NETGEAR PS121 Mini Print Server Resource CD to run the Add Printer Port Wizard to set up each PC on you network that you want to use with the PS121. Select the port you added
You may also use the links below as your guide to troubleshoot the print server:
http://kbserver.netgear.com/kb_web_files/n101269.asp
http://kbserver.netgear.com/kb_web_files/n100033.asp
However, if this does not resolve the issue we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Model number of router
2. Model of printer
3. Operating system of computer/s
May 01, 2009 | NetGear PS121 Print Server
NetGear PS121 Print Server Problem
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
2. Model of printer
Apr 26, 2008 | NetGear PS121 Print Server
Access Denied
This is a software issue. Sounds like it needs to be reinstalled but someone with password access.
Jan 23, 2008 | HP LaserJet 6L Printer
How To Configure FM114P or FR114P for an Internet Connection and Printer Sharing
There are three steps: 1. Configuring the router for Internet access 2. Installing and configuring the print server 3. Adding the printer to the Windows configuration To Configure the Router for Internet Access 1. Connect the modem to the router's Internet port and your LAN computers to the router's LAN ports. 2. Shut down your LAN computers. (Power them off.) 3. Power off the router. 4. Power off the modem. 5. Power on the modem. 6. Power on the router. 7. Start the LAN computers. 8. Enter 192.168.0.1 in a Web browser's address. 9. Type username and password (by default admin and password). 10. Click Setup Wizard to configure the router's Internet access. To Install and Configure the Print Server 1. Install the Printer Server Driver program on a computer. 2. After installation, make sure to select the Run Print Port Setup now box. 3. Click Finish. Print Port Setup runs, showing you the firewall and the printer. 4. Click Port 1. 5. Click Add. A pop-up message says whether a port was created, then the Add Printer wizard starts. To Add a Printer With the Windows Add Printer Wizard 1. Continuing from the last section (or clicking Start > Settings > Printers > Add Printer), click Next. 2. Select Network Printer, and click Next. 3. Click Next again (leaving the port as LPT1). 4. Select the manufacturer and printer model of your printer. (If your printer does not appear, you need to get the CD or floppy that came with the printer, and use Have Disk to specify the file location. Note that it is looking for a file that ends with .inf.) 5. Click Next. 6. Change the printer name to something users on your LAN will recognize easily. 7. If prompted by the Add Printer Wizard about sharing: DO NOT enable sharing! Now test the printer. Other information about Windows configuration is available in Windows help in the article "To connect to a printer on a network".
Feb 19, 2006 | NetGear FR114P Router
Feb 19, 2006 | NetGear FM114P Cable/DSL ProSafe 802.11b...
1,054 people viewed this tip
David Payne
David Payne
