Tip & How-To about Computers & Internet
Tips to Choose a Fiber Optic Modem
Fiber optic modem is good for you, especially when it comes to large amounts of data. With this modem, you can transfer your data quickly and efficiently. In general, this modem is available in two models, the single and multimode. Before buying, be a wise decision to consider certain factors that may be the best for their needs.
When you purchase a modem mode only for businesses, a single-mode modem is ideal for you. It allows some networking systems to share and provide information in large quantities over long distances. This mode also in the light traveling back and forth that allows you to transmit data in both directions simultaneously.
On the other hand, if you need to buy a fiber optic modem for your personal needs, is ideal for multi-buy option. Even if it is available at cheaper prices, it still exceeds the traditional cable connection. With this modem, you will be able to receive and transmit information quickly and easily
Another consideration that you have to do is how you use your computer now and in the future. If you use your computer primarily to receive calls and faxes, a telephone modem to two son to be a good choice for you. It is able to easily translate the phone lines light easily sent by optical fiber.
There are many companies that offer this type of modem you have to do a search. Can help you choose the most reliable product with reasonable price. Check the specs and product offerings to see whether or not it meets their needs. Choose the best solution for your needs.
Computers & Internet Logo
What are the benefits of green tomatoes?
Green tomatoes provide us with the following benefits:
They contain a large amount of calcium.
They contain a large amount of vitamin c, which strengthens the immune system.
One cup of green tomatoes contains 2 grams of fiber.
They contain large amount of beta-carotene, which helps the body to produce vitamin a.
Jan 17, 2013 | Cooking
Dear all. We use twin modem V.3266 of Motorola to connect data from PLC A&B to SCADA via fiber optic cable and Mux (NEC 6000), but now two modem are usually display training status, and data don't transfer to SCADA. please give me instruction to solve this problem. Best Regards Luu Dinh Quyet
Hi Mr Q,
You would need a big check-up on:
1. PLC (Comm card - Prosoft ?)
2. Modems
3. Multiplexers
4. Optical Cables
5. RS232 Cables
6. Comm Port Spliter (MOXA?)
7. SCADA System (Oracle Database ?)
Please let me know your above check-up results so I provide further help.
TBT
Oct 26, 2010 | Arris V3229 (6209526200030) Modem
Hangs on large installations or data transfer
THat means that there is something wrong with the drive already. I can transfer up to 100 Gig of a single file to large USB drives so generally transferring is not a problem. Try formatting the drive then transfer again. Or your USB port on your computer is only a USB 1.1 and not USB 2.0
Feb 07, 2009 | SimpleTech 320GB SimpleDrive External by...
1,166 people viewed this tip
David Payne
David Payne
