Tip & How-To about Televison & Video
How to clean an LCD TV
An LCD screens must be cleaned as it attracts dust like a magnet. Cleaning is risky as the screens are very sensitive and there are chances of you damaging the screen if you don't know the proper method to clean it. To help you in this read the article below to the various tips on cleaning the LCD TV. Tips On Cleaning LCD TV Basic Facts About LCDs
  • LCD screens or displays should not be cleaned through normal methods, as they are not glass. LCD or liquid crystal display is a soft film and it can be damaged through improper cleaning agents.
  • The popularity of LCD TV's is on a rise as they can be can be run on low battery power and also havesharp picture clarity.
LCD Screens Problems
  • LCD screens regularly gather dust and smudges and sometimes fingerprints and ink markings.
  • Cleaning the screens with a paper towel, dishcloth or tap water can do considerable damage, as the screens are very sensitive. It can cause clouding and can cause damage to the pixels.
  • Tap water contains chemicals like chloride and wiping the screens with it can leave a residue on the screen.
Cleaning Tips And Guidelines
  • The LCD TV must be cleaned regularly for you to enjoy the proper clarity of the display.
  • First of all, turn off the LCD TV and examine the condition of the screen.
  • Note the smudges and the areas to be cleaned.
  • To remove dusts use a microfiber cloth and brush off the dust particles.
  • It is best to use proper cleaning solutions that come with LCD cleaning kits. However, you can mix one part of isopropyl alcohol with one part of distilled water and using cotton or microfiber cloth, clean the screen. Another cleaning solution that can be made at home to clean LCD TV's is to mix one part of vinegar in one part of water. Pour this solution on a soft cloth and then wipe the screen.
  • Take care not to spray any sort of cleaning solutions directly onto the screen. Instead take it on a piece of cloth and then wipe.
  • Wipe the screen in a circular motion and be very gentle. Don't press hard.
  • Also do not touch the screen with your fingers or there are chances of leaving oily prints.
  • Rub a soft cotton dry cloth to completely remove excess liquid from the screen as the moisture may damage it.
  • Before switching back the TV on, let the screen dry completely.
  • If some stains or marks are hard to remove, don't apply pressure to remove it. Instead, repeat the cleaning procedure several times to get rid of it. For ink marks and other hard stains, you have to invest in special cleaners.
  • To clean the dirt from the edges or corners use a Q-tip. Dip one end of the Q-tip in the cleaning solution and squeeze out the excess moisture from the cotton tip. Now gently drag this tip along the edges.
  • Do not use cleaning solutions that contain ammonia, ethyl alcohol, acetone, toluene, ethyl acid, or methyl chloride. These chemicals can react with the LCD screen materials and damage it.
Televison & Video Logo
how do I disassemble a Vizio E3D470VX Smart TV, to clean out the dust inside the Screen
Hi Alonzo,
To clean the dust inside the screen, you will have to disassemble the LCD panel. It is a very risky job and there is every chance of damaging the LCD screen unless you have a real good experience of doing it. If you are not good at doing such jobs, please let some professional do it for you.
Jul 05, 2016 | Vizio Televison & Video
How do i clean my vizio tv without damaging it?
There is a screen cleaner you can buy at any store like the source, future shop , best buy that sells it, it is called monster screen cleaner it is a bit expensive but will not damage your tv screen
Apr 08, 2010 | Vizio L32 32 in. LCD HDTV
JVC HD 56GC87 PICTURE NOT SHARP
On a tv whether it be projection type, plasma or lcd screen, new or old, 2 1/2 years is sufficient time for dust and lint to accumulate inside the tv and its components. Those lamps are a good place to start. There are external factors like humidity, temperature, and the cooling of that tv that can affect the picture over time. To clean those bulbs/lamps you need to be careful and use a lint free cloth like they sell at Home Depot or Lowes. I call them detail rags because they attract lint and moisture and leaves the surface dry. Also a can of clean compressed air like they sell at Radio Shack or most electronic supply stores can be used to clean the dust and lint accumulation on the components. The cooling fans on those tvs and any for that matter are notorious for bringing into the tv anything that is floating in the air. So I would first blow clean compressed air on all the components you may see dust and lint accumulation even the bulbs before I use the detail rags to take any remaining residue from the lamps. The inside of the screen should be cleaned as well. Be sure for safety to disconnect the power to the tv and to touch the frame of the tv to discharge any static electricity you may be carrying due to carpet floors or other objects so that you do no inadvertently damage a sensitive component. On HD tvs all the components other than those bulbs are static sensitive. Just be aware of that. Should this type of cleaning not improve the quality of the picture then I would have to assume that the voltage from the power supply supplying the voltage to the lamps is getting lower with age. On that I can probably help you depending on what you are comfortable doing with your tv in adjustments if there are any. Let me know and I'll be glad to lead you through it if necessary. Good luck and God bless you. Robert
Jan 06, 2009 | Televison & Video
575 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
