Tip & How-To about Cameras
Memory Cards: 'Locked', 'unrecognised', recover images, and 'format'
'LOCKED'
It is not always obvious that memory cards have a means of physically protecting them, so nothing more can be written, or deleted. When you switch on the camera with a card in place which is 'locked' in this way, it will be reported on the screen but luckily it is easy to put things right.
The most popular type of card is currently SD or SDHC which has a tiny tag at the top on the left side when facing the label, but other types of card have similar sliding tags which act like a switch to 'lock' the card.
When handling a card, or when fitting it to the camera, it is all too easy for the tag to be moved by mistake into the locked position.
A small illustration indicates the locked position so you can move it carefully in the unlocked direction. No force is needed so, if it is hard to move, have another look to see how it works before doing any damage.
'MEMORY CARD ERROR/CARD UNRECOGNISED'
If there is a message like this or e.g. 'this card cannot be used', or if the images appear scratched or damaged when viewed on the screen, the files on the card have probably become damaged or disorganised and the best way to proceed is to format the card, see below. If there are images on the card you want to keep they should be saved to another medium, or if you cannot do this, or if images have apparently disappeared, they can probably be recovered, see below.
IMAGE RECOVERY
Even if you have wiped a card clean by formatting, the images can probably be recovered. There are many programs available to do this, free to download and use. e.g.:-
http://www.freedownloadscenter.com/Utilities/File_Maintenance_and_Repair_Utilities/Easy_Flash_Recovery.html
FORMAT
If the card cannot be recognised or shows an error then it can usually be formatted in the camera: In Playback Mode, Menu> Setup >Format. If this does not work then you can format the card in PC by right clicking its icon in My Computer to bring up the option. Then format again in the camera to ensure full compatibility.
Cameras Logo
kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
Memory Cards: 'Locked', 'Card Error', 'image recovery, and 'format'
Every time i put a memory card in the camera, the camera seems to un-format or ruin the card. The card worked fine in a different camera until i put it in this one. Now everything seems to be deleted and screen says memory card error. I'm about to give up!!!!!!!!!.........
Jan 18, 2011 | Cameras
what does card protected mean?
Wheb you have a SD, SDHC or SDXC memory card and you put the switch to the lock position, the card is protected, That means nothing can change the files that are stored on the card. Not by wiring, not by deleting and not by formatting. Keep the lock with up, towards the golden connection points.
On the picture the 64 GB card is unlocked. `the 32 GB card is locked 8ab871eb-243a-48dd-a8d8-58e5df95d568.jpg
Dec 29, 2013 | Vivitar ViviCam 8025 Digital Camera
What does 'Write Protect' mean and how do I get rid of it?
That means that your SD card (or whichever memory card you use) is write protected and you cannot edit the card's content in any way.
Take your memory card out of the camera and plug it into your computer. There should be a place for you to change the memory card's protections that way. Sometimes, as with USB drives, there might be a small sliding lock physically located on the card which will also write protect the device.
Apr 09, 2010 | General Electric A735 Digital Camera
Memory card locked!??
The card locked usually means 'protected' Check out the manual for image protection - on/off. Or put card back into computer and delete[NOT FORMAT] from there. A more comprehensive manual is usually found the the CD that came with the camera
Jul 05, 2007 | Pentax Optio E10 Digital Camera
555 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
