Tip & How-To about Computers & Internet
You cannot print or print preview Web pages in Internet Explorer on Windows
Symptom:
When you try to print a Web page in Internet Explorer 7 or in Internet Explorer 8 on a computer that is running Windows Vista or Windows 7, the Print dialog box disappears, and nothing is printed.
Additionally, if you print preview a Web page, the Print Preview page may be blank except for the page number in the header and a file path and date in the footer. The file path resembles the following:
File://C:\Users\<username>\AppData\Local\Temp\Low\RU4GX5A5.htm
Cause:
This issue can occur if the "C:\Users\<username>\AppData\Local\Temp\Low" folder has been deleted. Some applications, such as disk cleanup utilities, can delete this folder during their cleanup process.
Note: <username> refers to the currently logged on user who is experiencing the issue.
Resolution:
To resolve this issue, follow the methods that are listed in this section starting with Method 1.
Method 1: Restart Internet Explorer
loadTOCNode(2, 'resolution');
  1. Close all instances of Internet Explorer.
  2. Restart Internet Explorer.
  3. Print or print preview a Web page in Internet Explorer.
If this method does not resolve the issue, go to the next method.
Method 2: Re-create the missing folder
  2. Click Start, type %Temp% in the Start Search box, and then click the Temp folder in the list.
  3. If you are running Windows Vista, click New Folder on the Organize menu.
    If you are running Windows 7, click New Folder on the main menu.
  4. Type Low for the folder name, and then press ENTER.
  5. Close the Windows Explorer window, start Internet Explorer, and then print or print preview a Web page.
Method 3: Reset low integrity level on the Low folder
  1. Click Start, click All Programs, and then click Accessories.
  2. Right-click Command Prompt, and then click Run as administrator.
  3. At the command prompt, type the following command and then press ENTER:
    ICACLS "%userprofile%\AppData\Local\Temp\Low" /setintegritylevel (OI)(CI)low
  4. Restart the computer.
  5. Print or print preview a Web page in Internet Explorer.
The information in this article applies to:
  • Windows Internet Explorer 7, when used with:
    • Windows 7 Enterprise
    • Windows 7 Enterprise E
    • Windows 7 Home Basic
    • Windows 7 Home Premium
    • Windows 7 Home Premium E
    • Windows 7 Professional
    • Windows 7 Professional E
    • Windows 7 Starter
    • Windows 7 Starter E
    • Windows 7 Ultimate
    • Windows 7 Ultimate E
    • Windows Vista Business
    • Windows Vista Business 64-bit Edition
    • Windows Vista Enterprise
    • Windows Vista Home Basic
    • Windows Vista Home Basic Beta
    • Windows Vista Home Premium
    • Windows Vista Starter
    • Windows Vista Ultimate
  • Windows Internet Explorer 8, when used with:
    • Windows 7 Starter
Computers & Internet Logo
Error 105 (net::ERR_NAME_NOT_RESOLVED): The server could not be found.
Which is your browser and operating system? Anyways i would suggest you to perform all this so try.
http://support.mozilla.com/en-US/kb/Support+Website+Forums
Firefox Support at above link.
See if the information below helps to resolve the issue/s you are having with Internet Explorer:
http://support.microsoft.com/default.aspx/kb/936213/?p=1
"How to optimize Internet Explorer"
Configuration settings in Windows Internet Explorer 7 and Windows Internet Explorer 8 may cause one or more of the following issues:
· You experience performance problems in Internet Explorer.
· You receive an error message in Internet Explorer. For example, you receive an "Internet Explorer cannot display the Web page" error message.
· Internet Explorer stops responding.
The above article describes how to optimize or reset Internet Explorer in Windows Vista to resolve these issues.
http://support.microsoft.com/kb/936215
"How to troubleshoot Internet Explorer issues in Windows Vista and in Windows XP"
This article discusses how to troubleshoot possible issues that you may experience when you use Windows Internet Explorer 7 or Windows Internet Explorer 8 on a computer that is running Windows Vista.
http://support.microsoft.com/kb/936214/
"How to troubleshoot compatibility problems that affect Internet Explorer 7 in Windows Vista"
This article describes how to troubleshoot software compatibility problems that affect Windows Internet Explorer 7. To help determine which program may be causing the problem, you can take the following steps:
1. Use safe mode with networking
2. Perform a clean boot
3. Use a different user account
4. Scan your computer for viruses and spyware
5. Run Internet Explorer 7 in "No Add-Ons" mode
Hope the above helps.
Cheers.
Dec 27, 2010 | Facebook Social Network
Problem signature: Problem Event Name: APPCRASH Application Name: iexplore.exe Application Version: 7.0.6001.18319 Application Timestamp: 4a966702 Fault Module Name: StackHash_89d3 Fault Module Version: 6.0.6001.18000 Fault Module Timestamp: 4791a783 Exception Code: c0000374 Exception Offset: 000aada3 OS Version: 6.0.6001.2.1.0.768.3 Locale ID: 1033 Additional Information 1: 89d3 Additional Information 2: 1ed8fc0e7cdbac8f97149f1811e3a2be Additional Information 3: 6b78 Additional Information 4: 999f1b8c5be80cb7aef501c344265524
While loading/viewing a web-page, using Microsoft Internet Explorer Version 7, under Windows Vista (4=WindowsNT, 5=Windows2000, 7=Windows7), it "crashed".
Try the same web-page from another computer also running Vista and IE7. If it works, then something on your computer is the problem.
Restart your computer, and try again to access the same web-page.
If you get the same problem, upgrade to Internet Explorer 8, and try again.
If you still get the same problem, contact the author of the web-page, and get them to investigate.
Dec 08, 2009 | Microsoft Internet Explorer 7
yahoo chat
  1. The Web Page that you are trying to reach might be out of service. Try visiting different Web sites to see if this message still displays from other sites. If visiting other sites also cause the message, continue using these steps.
  2. If you are using IE 7, reset Internet Explorer 7 settings and try again. If the page display problems persist, continue.
  3. In Windows Vista, click Start c00866085.gif , and then enter the following into the Start Search field: regsvr32 softpub.dll In Windows XP , click Start , and then Run enter the following into the open field: regsvr32 softpub.dll
  4. In Windows Vista, click Start c00866085.gif , and then enter the following into the Start Search field: regsvr32 urlmon.dll In Windows XP, click Start , and then Run enter the following into the open field: regsvr32 urlmon.dll
  5. Restart the computer and then try browsing the Internet again. If the page display problems persist, continue.
  6. Open Internet Explorer and click Tools , and then Internet Options .
  7. Click the Programs tab, and then click Reset Web Settings .
Sep 23, 2007 | Computers & Internet
yahoomessenger
Sep 15, 2007 | Computers & Internet
535 people viewed this tip
David Payne
David Payne
