Tip & How-To about Cell Phones
How to format Nokia N- Series mobile
This is common problem that how to format Nokia N- Series mobile
Three methods are given below by which you can format your Nokia N- Series mobile
Method 1:
First of all Switch off your mobile then press and hold 3 keys combined
  • Green dial key (Call answer button)
  • Star key no *
  • No 3 key on keypad
then press the power on to switch on the mobile.
  • In the process don't leave the 3 press and hold keys
Now wait for message "Formatting" to appear on the screen and release all keys once you see that message.
If it as security code then default security code for Nokia is 12345
Method 2: Hard Format
  • Type *#7370# from your dial keys
  • It will ask you to confirm that press OK
  • It will take some time and your mobile will be formatted & restore settings to default factory settings
  • If it as security code then default security code for Nokia is 12345
Method 3: Soft Format
  • Type *#7780# from your dial keys
Note: Remember one things by Method 1 & Method 2 this will deletes all your messages, all contacts, photos, notes etc in the phone memory.Your mobile is like a new mobile. So better is first save all your data and then format it. By Method 3 (Soft Format) it only restores your mobile & do not delete your data.
If it helps you Please Click on "Yes" that it helped you
Cell Phones Logo
code error for Nokia 6600 "Lockj
UNLOCKING PHONE
Hi you can use codes to unlock the mobile . to get the unlock codes visit this link:http://www.unlocking4free.com/
Here they ask the following details before rendering the unlock codes they are 1. Mobile model 2. Country from where you brought the mobile 3. Provider to which the mobile is locked 4. Imei number of the mobile Finally they will send you the unlock codes at free of cost.once you entered the code in your mobile as for the instruction given by them .your mobile get unlocked and it accepts any network sim to get the IMEI: UnlockPhone Via IMEI. Your phones IMEI is your unique number that is given to eachphone. For each IMEI there is a unique unlock code that once entered into your phone will enable you to use any compatible sim card. You can get theIMEI for your phone by entering*#06# into your keypad. You will only need 1 unlock code to enable you to use any sim card in your phone and enable it to be "network sim free".
you can also try going to this site:http://www.foneszone.co.uk/unlock_codes/ though this site may not guarantee a free service..
or you may try one of this:
reformatting NOKIA Series phone:
simple ways to format your Nokia NSeries cell phones.
(Please do remember that some of the steps below will clean up all your data in phone so remember to make up backup copy of it. Otherwise you will end up loosing them forever.)
Method:1
1. Switch off the phone.
2. Hold down the following three buttons: Green (call answer button, * button, and '3? button.
3. While holding these buttons, press the power button and switch on the phone.
4. When the message 'Formatting' appears on the screen, release all of the buttons.
Method: 2 ( Hard Format)
2. Hold down *#7370# button.
Method: 3 Soft Reset
2. Hold down *#7780# button.
http://techalites.com/2008/05/06/how-to-format-nokia-n72-n73-n81-n95-nseries-phones/
please give time to: ---a score of 4 is highly appreciated----- ---if you think this resolution is helpful kindly click on "YES"---- ---you may also leave testimonial----- ---if I help you please help me---
Thank you for choosing fixya
Roger
Sep 08, 2011 | Nokia 6600
my phone get hang frequently
this is a genral problem in nokia n series phone.the only solution exist now a days to overcome this problem is to format the phone
How to Format Nokia N72, N73, N81, N95, NSeries Mobile Phones. Method 1: Three Finger Reset for Nokia Phone
1. Switch off your Nokia phone.
2. Hold down the following three keys, Green (call answer button) * Key, and Number '3? key.
4. Wait for message 'Formatting' to appear on the screen and release all keys once you see that message.
Method 2: Hard Format of Nokia Mobile Phone
2. Now Press following key sequence *#7370#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message 'Formatting' to appear on the screen and release all keys once you see that message.
Method 3: Soft Reset of Nokia Mobile Phone
2. Now Press following key sequence *#7780#
Please Note: The Above Nokia Phone Formatting method will erase all your Phone data. So do backup before proceeding for Formatting
Jan 24, 2011 | Nokia N73 Cellular Phone
when i power on my n95 8gb its writing : phone start-up failed. contact the retailer . what i must do
hi
there must be software corruption in your mobile. kindly format your phone . this will able to fix your problem if still having this problem means then there must be some hardware problem in your mobile. kindly ask your service provider to fix this problem. but formatting your phone will fix your problem
thank you
Dec 20, 2010 | Nokia N95 Cellular Phone
i hard format my nokia E63. now is asking for lock code i use 12345 doens't work help me pls
again format your phone using the method given below
first switch of your phone then press the star(*) three(3) and call button holding these button and switch on the screen displays blank white screen for sometimes and then on
then try.if ur problem again exist,reinstall the phone software(flash) with the help if a mobile mechanic.re-installation reset your code to 12345or 1234
Oct 26, 2010 | Nokia E63 Cell Phone
nokia n72 problem
Try any these:
Method 1: Three Finger Reset for Nokia Phone 1. Switch off your Nokia phone.
2. Hold down the following three keys, Green (call answer button) * Key, and Number ‘3? key.
4. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message.
Method 2: Hard Format of Nokia Mobile Phone 1. Switch off your Nokia phone
5. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message.
Method 3: Soft Reset of Nokia Mobile Phone 1. Switch off your Nokia phone
Dec 09, 2009 | Nokia N72 Cellular Phone
3,374 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
