Tip & How-To about Samsung SCH-U450 Cell Phone
How to remove the battery from a Samsung Intensity cell phone
If you ever need to replace your Samsung Intensity's battery, or if you just want to remove and reinstall it to reset the phone, getting the battery out is a piece of cake.
First, turn your phone off by holding down the End button (the button to the far right of the directional pad) for a couple of seconds, until the phone begins to shut down. Then turn the phone over so you're looking at the back of it. (The battery can be removed with the slide-out keyboard either out or in, but the phone is a little easier to grip if the keyboard is in.)
The rear cover of the phone pops off easily as one piece. You can fit a fingernail in the groove along the top of the cover (by the camera lens) and the cover should come right off. Once the cover is off, you're looking right at the battery. It's the rectangle-shaped thing in the middle of the phone (that probably says "Samsung" on it). There is a little ditch on the bottom edge of the battery where you can put your finger to lift the battery out of its cavity, and once you lift it up it can be removed easily.
When reinstalling or replacing the battery, slide the top side (the side with the three gold contacts) in first, and the notches will line up as the battery falls into place. The battery is keyed so it can only be inserted one way; if it does not slide in easily, make sure the gold contacts on the battery are lined up with the gold contacts on the phone. When the battery is back in, reattach the rear cover (making sure it snaps into place) and turn the phone on by holding down the End button for a second or two.
Samsung SCH-U450 Cell Phone Logo
I can't shut my Samsung Verizon cell phone off
Perform a hard reset, (Hold the power button and volume down button for ten seconds, release when the phone starts to restart.) or if you can remove the battery, do so. Good Luck!
Feb 05, 2016 | Samsung Intensity II U460 Verizon
samsung factory reset
Regardless of what button is pushed the phone goes into the calendar and proceeds to cycle through all the dates. The only way to stop it is to remove the battery.
Jan 02, 2014 | Cell Phones
the screen on my samsung intensity is rotated even with the keyboard is closed?!
HI mogulmonkey take the battery out of the phone. Then take the phone and plug it in the charger. When you remove the battery it is a soft reset . Their maybe a software issues with the phone.
Feb 19, 2011 | Cell Phones
Where is the port on a samsung intensity cell phone?
The port on a Samsung Intensity is located inside the back cover of the phone. Take off the back of the phone, and you'll see the port, right next to the camera key button. (You won't need to remove the battery.)
Oct 07, 2009 | SanDisk 2GB microSD Memory Card
2,508 people viewed this tip
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
