Tip & How-To about Cell Phones
How to find IMEI number of Cell Phone
Hello
Press *#06#
You can also find out by turning the phone off and removing the battery. The IMEI number will be printed on the sticker under the battery.
Hope this helps, if so do rate the Tip. Good Luck
Cell Phones Logo
how to repair imei for nk 3110 give me solution
Hello
Press *#06#
Hope this helps, if so do rate the solution. Good Luck
Jan 17, 2011 | Nokia 3110 Cellular Phone
how to get IMEI number for Nokia in j2me
To get the IMEI number please press *#06#.
It will display in your screen.
If you dont get the IMEI number by this code please open up the cover and remove the battery.On the phone there will be a sticker in which IMEI number is printed.
ad0f3a6.jpg Thank you.
Aug 09, 2010 | Nokia 2680 Slide Cell Phone
I lost my sony ericsson mobile can you help me to gfind out using IMEI no?
HOW TO FIND IMEI NUMBER
  1. Ensure your phone is powered on.
  2. Return to the "idle" screen, or your "desktop". If you were in the middle of a call, end it, and clear any numbers you pressed while making that call.
  3. Press the following keys one by one: * # 0 6 #
  4. As you press on the last #, a number will appear with the title, IMEI number, or similar.
  5. And if you store this *#06# as a phone number in your contacts with the some name, say, IMEI Code, then next time when you dial IMEI Code from your contacts, it will show you the IMEI Number. That way you won't forget the *#06# sequence.
OR
  1. Ensure the phone is powered off.
  2. Remove the battery.
  3. Look on the phone for a white sticker/label, which would be now exposed after removing the battery, for the IMEI. It would be 15 or 17 digits not including a few forward slashes included and without any letters. Only the first 15-digits are needed.
  4. If the phone is not available or if the label is unreadable then have a look at the phone manufacturer's packaging for a white sticker/label. Near one bar code or another the IMEI would also be printed.
Jun 24, 2010 | Sony Ericsson W200i Cellular Phone
imei number
hi your imei number is you phone identification number each moblie has there own unique one and to find it you just type in *#06# and it should bring it up automatically or you could just take the battery cover off then take your battery out and it will be on a silver or grey sticker hope this helps.
Feb 21, 2008 | Sony Ericsson Walkman W810i Cellular Phone
118 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
