Tip & How-To about Computers & Internet
Trick to Maintain MAC PC
Do you have a MAC? If yes, then this article is to read. Here you will find helpful tips to keep your Mac PC. You can also visit one of the computer repair services, offering support for Apple Mac to your Mac PC do its best. The boards are:
Check if a lot of disk space for the boot drive or not. MAC uses a little 'space on the hard drive as virtual memory when you do not have enough real memory. It 'always good to keep 10% of your hard drive for this activity. Remove unwanted language packs in OS X contains hundreds of languages, you're probably not going to use to save a bit 'more disk space.
Check the yard of unwanted applications. Dock should include only the most frequently used applications, so look through to see if there is something you can uninstall or delete. Select the appropriate applications, files, be wise in choosing what applications open by default - to think you really need to open Photoshop just look at the pictures, when the preview works fine? Right-click the file and then click Show Info
Check software version If you have an Intel Mac, then check the software structure is universal - it could be that the program is still running through Rosetta and that an update is available universally. Remove animation dock Go to System Preferences - Dock applications and uncheck
Animate opening. Avoid animated desktops Go to System Preferences - Desktop & Screen Saver, then uncheck the Change picture.
Computers & Internet Logo
remove genieo from mac
Genieo is a search engine program that will change your personal and default browser settings upon installation. Genieo is not usually considered a virus or malware program (although 21 security solutions list the Mac version as adware), but uses the keywords you enter into the Genieo search engine to generate an excessive number of sponsored links and ads mixed in with your search results. Follow the steps outlined in this article to delete the Genieo search program from your computer and all installed browsers.
Please visit and read it.
http://www.wikihow.com/Delete-Genieo
http://www.macissues.com/2014/04/23/how-to-detect-and-remove-genieo-for-mac/
Thanks,
Apple Support
Jun 05, 2014 | Computers & Internet
wireless connection from mac book to netgear router wrn2000 drops
I have the same problem and have read numerous articles on the same thing, it seems that MAC is having a problem with some of the aircards they put in the macbooks and should have a fix out soon.
May 16, 2009 | NetGear WG111 802.11g/b Wireless Adapter
Switching to a Mac
Your hard drive is probably formatted with the NTFS file system which is read only on MAC. The following article should guide you through making your drive writable on the MAC system. http://www.lifehack.org/articles/lifehack/how-to-read-and-write-ntfs-windows-partition-on-mac-os-x.html Regards, Armando
Apr 07, 2007 | Fantom Titanium Hard Drive
262 people viewed this tip
David Payne
David Payne
