Tip & How-To about Cameras
Trick For Using Your Digital Camera
With film cameras you always wondered whether there was sufficient exposure in the census, and if there was another roll of film. With the camera you can take lots of pictures and then immediately switch to eliminate those that do not want. If you do not have the photo you want, you can probably try again. This is particularly useful for taking pictures of the group - somebody who always has his eyes closed. The two things that determine the number of pictures you can take before the download is the resolution (quality) and the amount of memory in your camera. You can buy memory cards that increase the number of photos the camera can hold.
Although it is possible to print large-sized 8x10 the highest resolution, eat memory, which limits the number of images you can store your camera. If you think about it, how many times you are going to be printing 8x10. Option is always there when you need it, but I recommend the vast majority of the pictures are taken with a medium resolution. When you have time to test a new camera, use the lower resolution may take several times, until you learned what you can do every option of a digital camera.
This useful feature allows you to take better pictures in bright sunlight where dark shadows can ruin a great photo. You can also use the shadow which illuminates the image look washed out without the full flash can provide. "Fill Flash" This is not the normal flash setting, is generally known and is less intense than the normal flash.
A polarizing filter gives you more contrast and richer, warmer tone when shooting outdoors. A polarizing filter can be rotated to give the desired effect. If you have polarized sunglasses, try to keep the sunglasses in front of your face and look through one of the lenses. Rotate the sunglasses and the difference in tone and contrast of your environment.
That's what you can do with a polarizing filter. If you do not have a filter, you can use your polarized sunglasses - just take one of the targets as close to your camera. Oh - Make sure your sunglasses are clean!
Cameras Logo
Can't roll film for double exposure.
After taking the first shot, hold down the Multi-Exposure button while cocking the film-advance lever. This cocks the shutter without winding the film. You can continue to do this for as many exposures as you want. Just don't hold down the M-E button while cocking after the last exposure.
The Multi-Exposure button is the button on the front of the camera just below the shutter release button.
Apr 11, 2010 | Vivitar V3800N 35mm SLR Camera
Pentax SF10 Camera -- double exposure
If you press the film release button like you are going to rewind exposed film you may be able to activate the film advance lever to cock the camera so you can take another picture, and the film should stay on the first exposure allowing you to re - expose it. I would underexpose each image 1 F stop because.you are exposing the same film twice. Double exposures are always an iffy proposition and anything can happen. After the second exposure cocking the film advance should allow the film to advance once again. You might test this on the final pictures on a roll in case the camera won't start advancing the film after you try it. This way you won't blow a whole roll worth of pictures testing it.
Apr 12, 2009 | Pentax PZ-70 QD 35mm SLR Camera
Frame Counter Indicator does not go beyond the 26th and 27th Frame
Considering the age of the camera, you probably have a broken indicator gear in the top of the camera. The chances of getting it replaced aren't good. If it still works otherwise, I wouldn't worry about it. Just use 24 exposure film.
Jul 01, 2008 | Nikon FE 35mm SLR Camera
FRame Counter does not move beyond the 26th Frame even in a 36 roll Film
Simple, the film counter unit has plastic gears underneath. the gear position or gear has worned out. simply replace the counter unit and adjust. This can be performed by any local repair shop for less than $100. -James. for further assistance email, go to www.camerarepairjapan.com
356 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
