Tip & How-To about Computers & Internet
How to Perform a Defragmentation of your Hard drive, to increase performance!!!
When you install a program on to your computer's hard drive it just simply does so in the quickest way possible. Meaning it will install a program in the first available space that it can find, usually many different places, therefore resulting in what is known as fragments.
These fragments are often far appart causing your computer to become slugish as it has to find the fragments that it needs, to perform the task at hand.
You can therefore make your computer more responsive by arranging these fragments into contiguous pieces of information. In other words all information relating to a program is together in one piece making it quicker to read by your computer system.
This is done with the help of a program called Disk Defragmenter.
Follow these steps;
1.)Double Click My Computer
2.)Right Click the hard drive that is your system drive, usually drive C:
3.)Select Properties
4.)Select the Tools Tab on the top of the box.
5.)Under the Defragmentation heading click Defragment Now...
6.)Disk Defragmenter Now appears.
7.)Select the system disk again usually drive C: (The one with Windows installed on it.)
8.)Now click the Defragment button.
It will take a number of hours to complete, so only perform this when you have the time for it to finish.
The bigger your hard drive the longer it will take.
The benifit of this session is that it makes the computer operate more effieciently and will become more responsive.
The Disk Defragmenter is performed at about once a month, to maintain a good system.
Enjoy the extra performance!
damnor01
Computers & Internet Logo
all programs were read as shortcuts
You cannot simply drag and drop icons onto your Hard Drive. In order for programs to run off the hard-drive, you must have them installed to the drive.
Whenever you install a program and it asks where you would like the installed files to be placed, simply choose to have them installed on your external hard drive which is most likely name E:\ or F:\
May 31, 2011 | Western Digital (WD3200JS) 320 GB Hard...
I put about 30 Gigs of pictures on my wd 500gb hard drive and am trying to "safely remove hardware". but it says there is a program running that is using the hard drive and to close it. There are no programs that show up in the task manager...what do i do?
The quickest route would be to go through the shut down process on the computer. That will close out any processes that are still running. I would only do this if you are absolutely sure all the data has been transferred to the external drive. If you're not sure, leave it for a little while and check again later. Hope this helps : )
Jan 01, 2011 | Western Digital My Passport Essential...
how to upgrade win 95 to winxp without removing files installed
A computer running Windows 95 WILL NOT RUN Windows XP in most cases. Post all of your hardware details and we can explore that further.
Most programs that run on Windows 95 WILL NOT RUN under Windows XP easily. There are some compatibility things you can try for each one, but most simply will crash, and some will seem to work for a while then crash at inopportune moments.
What you should do is buy an newer computer with Windows XP, remove your current hard drive, and put your current hard drive as a second drive in the new computer. You will have access to your documents, but your programs will not run.
Mar 14, 2009 | Intel Pentium III, 800 MHz...
how do you install a fantom drive(titanium 2 firewire usb2.0.)or how do i psave programs to it.
You don't mention what kind of OS you're using - but either Windows, or OS X should see your drive regardless.
Before use:
Windows: Format the drive with NTFS.
Mac: Finder should pop up and ask you if you want to initalize the drive, you can choose 'yes' and continue.
Dec 02, 2008 | Computers & Internet
I just bought an iOmega eGo 160GB external hard drive and have no idea how to use it once I've installed the program. Help!!
From what I'm finding; this drive is a USB 2.0 drive. First, you'll need to plug the drive into the computer via the supplied USB cable (if it came with one) and any AC power for the drive if it requires it.
Then, your PC should detect it and you then need to run the software for it to be configured properly.
To use the drive, simply (if in windows) double click my computer and the drive will probably come up with a name such as eGo or iOmega Hard Disk or possibly even External Hard Disk. From there, double click that drive and start copy files! :)
Sep 11, 2008 | Computers & Internet
649 people viewed this tip
David Payne
David Payne
