Tip & How-To about Cell Phones
How to save your cellular battery
Before you plug your cellular into the electricity try to finish your battery first and only then enter it to the electricity, (every time will be the best if you can't once a month will be o.k)
if you can when you charge the battery shut down the Celluler and then charge the battery this way your battery will grip longer
Cell Phones Logo
My ACER Aspire 5635z won't turn on... When Iplug in charger it shows blinking led on batery sign... But I can not turn it on tried everithing... Can someone help me with this problem?
Try to :
Unplug battery and electricity.
press the startbutton 30 seconds.
Plug in electricity but not the battery.
Start, and let finish the boot.
If it works, turn off and connect the battery.
Start.
Good luck.
Sep 25, 2013 | Acer Computers & Internet
unlouck my cell
Hi there
Thanks for posting your problem on fixya
Please you visit this site first
http://www.lur.nu/nokia_mastercode/security_code.php
Dial you nokia mobile *#06# and your mobile generate a IMEI number put this number on IMEI area in the site and generate a master code and try it to unlock you phone
how to use it read it care fully
Remove the SIM card from your Nokia phone. This is typically done by removing the back cover of the phone and removing the battery and
sliding the card out. Put the battery back in and power the phone on.
2. You should see a message “Insert SIM Card”. Begin entering your generated code. Enter all of the characters you see in your code,
including the # symbols. To get a ’p’ press * 3 times, to get a ’+’ press the * key 2 times, to get a ’w’ press the * key 4 times. Disregard any
spaces in the code.
3. Once you have finished entering a code that works you should see a message that says “SIM is not restricted” or “Restriction off” message
depending on your model. If not, try entering another code. Be careful, entering a wrong code 5 times will mean that you will only be able to
unlock the phone with a data cable.
Pls rate this solution according to its use in you. it will be much appreciated........
Thanks
Robert
Sep 28, 2008 | Nokia 5200 Cellular Phone
nokia 5200
Hi there
how to use a master code read it carefully:
You will get a series of codes that looks something like: #pw+555 979 507 5+1#. You will enter each of these codes until you find the one
that works for you, it’s possible the first one won’t work.
3. Remove the SIM card from your Nokia phone. This is typically done by removing the back cover of the phone and removing the battery and
4. You should see a message “Insert SIM Card”. Begin entering your generated code. Enter all of the characters you see in your code,
spaces in the code.
5. Once you have finished entering a code that works you should see a message that says “SIM is not restricted” or “Restriction off” message
Thanks
Robert
Sep 20, 2008 | Nokia 5200 Cellular Phone
N95 flash light staying on all the time
does it have a waranty. contact your seller and try to negotiate. sorry for bad english..^.^
Jan 20, 2008 | Nokia N95 Cellular Phone
182 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
