Tip & How-To about Zenith DVP615 Portable DVD Player
How to change defective motor of portable DVD Player
This portable dvd player always says "no disc" everytime the disc's load.
I've checked it and found the faulty parts. The spindle motor that spin the disc.
Here's the step diagnosing the faulty motor.
1. Open the bottom cover of the portable dvd where the lens assembly is located together with the motor.
2.Pull-out the disc holder of the motor using the flat screw driver, you will see the small screw securing the motor from the assembly.
3. Unsrew the motor from the assembly.
4. Using the multitester set it at ohmmeter (X1) then test the motor.
Good Motor - reads fairly high resistance and it will spin.
Bad Motor - reads low resistance and it will not spin.
This test is also applicable at any DVD player.
5. After you confirmed that the motor was faulty then replace it with the new one and your unit will get back to normal again.
Upon installing the new motor, you have to consider the clearance of the spindle motor disc holder. Improper clearance will affect the reading of the optical lens. (check the clearance from the original motor)
Aside from the motor the most common problem also with no disc error is the FF:
Dirty Lens - this is prone to dust and any fine foreign objects that will block the optical lens from reading, gentle clean it with a soft cotton buds.
Lens ribbon - check the ribbon connected to the lens from the main board for scratch,damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the lead/contact with pencil eraser.
Hint : Almost 50% of my related dvd problem I've encountered with no disc error are caused by defective motor/ribbon, lens covered with dust. So you have an idea, try it to save some money sending your unit at the repair shop.
Good Luck.
Hope my tips may help you.
Thanks for visiting fixya..
JDVillanueva
Zenith DVP615 Portable DVD Player Logo
disc does not spin when inserted
check first weather the door switch not trigger so the spindle motor not rotating. if ok , the next thing you need to check is the spindle motor if still good or worn out using with the analog tester.
Oct 28, 2012 | Philips PD9000/37 Portable DVD Player
DVD PLAYER REPAIR (NO DISC ERROR)
I think the motor is okay, as it will load a cd. And it does seem like it comes up to speed. When I insert a DVD movie it tries to load,in about a minute it will spit it out. The display reads LOAD, does not give any othe message. I have the tools you speak of. I am a retired Electronic tech. But have not worked with Disc Players
Apr 18, 2011 | Bose 3 2 1 GSX System
help me to my toshiba sd-260 dvd player...can't spin the disk...said bad...
If the disc didn't spin, high chance that the spindle motor is already faulty. Check my tips on how to test the spindle motor and fix your unit yourself.
Faulty spindle motor tips 1
Faulty spindle motor tips 2
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 13, 2011 | Toshiba SD-260 DVD Player
my player when loading dvd loads for couple of secs and cuts off
Does the disc spin?
If not you have my problem spindle motor suspected faulty if the disc spins then its not being read, faulty lazer assy Try cleaning the lazer using dry brush disc philips do a good one and also clean the disc you are trying to play if it still doesnt work its a fault
Sep 02, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
unit stops spinning after loading & shows "no disk"
could be down to a dirty lens , faulty lens or faulty dvd player spindle motor.
jon
Aug 05, 2009 | Amphion Mediaworks M-520 Portable DVD...
4,492 people viewed this tip
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
