Tip & How-To about Cell Phones
MOBILE PHONE TIP'S
BEFORE UPDATING YOUR CELL PHONE CONNECT THE CHARGER AND KEEP IT ON, THIS WILL NOT SPOIL YOUR CELL PHONE, ALSO IF YOUR PHONE GOES BLANK KEEP IT CONNECTED AT LEAST 15 TO 20 MINUTE COZ SOME TIME THE PHONE GOES BLANK DUE TO UPDATES.
Cell Phones Logo
nokia c5 software dead
hi kiran...first i can advise u is never keep the battery connected when reloading the s/w...always use a power point...here i can advise u is to try switching phone on : remove battery , make sure no external power connected...press power button for 15 sec and keep it pressed then connect the charger and try to boot the phone...if fails please contact customer care
Feb 13, 2012 | Nokia C5 Cell Phone
I have a LG KP107b phone . from past two days my phone switch off automatically whenever i connect my phone to charger. with attached charger i cant switch on my phone but once i removed the charger and then try to switch on the phone it switch on. plz help me on this matter
Why the phone goes off when you connect the charger is because the connection was not straight up, so it will turn off the phone and it will go blank. When it does that, you just have to remove it, turn off the phone and remove the battery and insert it back in, then you fix in the charger before connecting it to the power outlet.
TIP: Always attach the charger into the phone first before you connect it to the power socket or outlet. That way it will never trip off when you attach it to the charger.
Thank you for using fixya
Caseytech
Jun 29, 2011 | LG Kp107 Cell Phone
t715 screen keeps goin blank
hi :) T715 should aslide phone right?? the scren will blank,cause phone ribbon was spoil. pls send to mobile shop to change a new ribbon to solve your pro. Good Luck.
Jul 06, 2010 | Sony Ericsson T715 Cell Phone
dear sir, I have a nokia 6681 cell phone,I was updating the software on it sudendly my net connection break down and my phone became blank,now it it is not reading the usb of the computer.please give your expert advice. with regards, anas sayed my email id is sayedanas10@yahoo.com
Dear Friend,
When Updating is progress,firstly it will erase Previous data. Then it will Write New Firmware to your Phone.
  • Now it made break and New File not Updated as Right Way
  • It is necessary to be in NORMAL MODE for Connect Via PC SUITE to UPDATE
  • SO please Ensure while doing this things like availability of Power & Internet Connection....
You can do Following
  • Try to remove battery from phone
  • Keep it in a safe Place for some Hours
  • Please make Sure CHARGE OF BATTERY
  • Try to switch on
  • Keep Trying to Connect Via PC Suite
If u made Connection ...You are Done....
In this Condition most of the time Need Flasher to reprogramme the MOBILE......Then you may/Should need Manual Flashing.........
IS this Helped you.........Rate me......
Thanks for using FixYa
Apr 01, 2010 | Nokia 6681 Cellular Phone
my phone wont turn on. All that i get is a blank white screen and it vibrates twice
Please connect the phone to a power outlet. Let it charge for 15 minutes and then switch it on. This happens when it is out of power.
Aug 21, 2009 | Sony Ericsson K550i Cellular Phone
146 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
